GM ECU spark table? - Team Camaro Tech
Old Nov 10th, 12, 09:05 PM
sweetblue69 sweetblue69 is offline
Daniel
Default GM ECU spark table?
I've got an ECU I'm going to use GM #16198262 and it has a custom chip in it for a 502ci crate engine. The harness it came with doesn't have the wires connected for a GM HEI/EST (computer controlled electronic spark timing with external coil) but I know the functionality is available for the entire series of ECU's but the custom chip maker (unknown) may have nulled the spark table(s) or it could be for a small block or other engine that doesn't require as much advance.
How do I test for spark advance functionality without using an eprom reader? Is there a good website out there specifically for GM EFI applications? I've only managed to find little bits and pieces.
Old Nov 11th, 12, 06:56 PM
Steiner Steiner is online now
Steiner
Default Re: GM ECU spark table?
There's probably a wealth of info on thirdgen.com so I'd ask over there. Might be able to find someone who could look at it for you. Tunercat works with those old ECM's although I know nothing about it. They have free 30 day versions of their software on their website tunercat.com but you need the burner I reckon.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
