Holley carb - Team Camaro Tech
Old Nov 12th, 12, 02:36 PM
dill dill is offline
Question Holley carb
What carb is best for a mild bbc the street avenger 870 or the 82750 holley
Old Nov 13th, 12, 05:39 PM
bigblockragtop bigblockragtop is offline
mike
Default Re: Holley carb
There are tons of info about this all over the web and this site. Do a search and you will be reading all night. That said the 750 lower end torque the 850 high end power. I prefer the 750 but that's me.
Old Nov 13th, 12, 05:49 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
The Quick Fuel 750 VS carb is getting lots of play and folks seem to be happy with them. I think the Quick Fuel guys used to work at Holley, but don't quote me on that.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Nov 13th, 12, 05:55 PM
bcm66's Avatar
bcm66 bcm66 is online now
Bryon / Big B
Anything from 750 to 850 should be OK for a mild BBC, depends on how mild as to which one you go with.
My personal choice would be an old 3310 or 3310-1. These both have 2 metering blocks and are 780 cfm. The new 3310 carbs (3310-2, 3310-3, etc,) are rated at 750.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Nov 17th, 12, 07:06 PM
Straight-line-69 Straight-line-69 is offline
I guess the primary diff between the two is, one has a choke and one doesn't. If you go 'chokeless' you'll have to work the throttle quite a bit for the first five minutes of driving,..a bit annoying.
What tranny and rear gear?
Old Nov 18th, 12, 05:27 AM
DT DT is offline
Donny
Wow, we must be on the same page, LOL. I just removed my 870 Holley SA from my BBC and was thinking about replacing it with the 82750. The 870 ran very good, however I couldn't dial in the choke for some reason and it never really worked properly. If I had to do it again I would not recommend the 870. I think it was a little big for my set-up. Perhaps the 770. Anyway, JMHO. Right now my choices are between the 82750 and the Quick fuel HR780 vs. Here is a link to the QF carb: http://www.ebay.com/itm/QUICK-FUEL-H...sories&vxp=mtr
396 X66 LeMans Blue, M20, 373 ...
Old Nov 18th, 12, 08:55 PM
norcal_68 norcal_68 is offline
Team Member
Mike
Need more info, how many cubes? Manual or automatic? Mech secondaries for manual, vac for auto.
Old Nov 20th, 12, 02:09 PM
DT DT is offline
Donny
AAhhhh, Not so fast.... Here is a recent post ( # 3 ) about the Quick Fuel.
http://www.camaros.net/forums/showthread.php?t=214037
Old Nov 20th, 12, 06:19 PM
It is a 461 cubes 410 rear tb 400 trans iron heads 575 lift comp magum cam. I would like to go 850 carb?
