Advice shopping for Pro Touring Camaro - Team Camaro Tech
Pro Touring Todays performance with classic style
Thread Tools Display Modes
Old Nov 12th, 12, 04:54 PM
Bucco47 Bucco47 is offline
Chris
Default Advice shopping for Pro Touring Camaro
I just sold my 69 that was basically stock and am now considering making the leap to a pro touring where someone else has done the expensive work on modern upgrades. My concern is with the ones that have LS1, LS2, etc engines in them that previously lived under the hood of a Corvette 10 years ago. It seems like an enormous risk not knowing, really, how many miles are on the drivetrain which i can't work on like i could my normally aspirated 327.
Any thoughts from someone who has already made this leap.
Chris
72 Camaro RS/SS, 383, Dart Heads
http://i197.photobucket.com/albums/a...ps6f910afa.jpg
Old Nov 12th, 12, 06:51 PM
XLexusTech XLexusTech is offline
Rico
Default Re: Advice shopping for Pro Touring Camaro
Well... if you go LS3 then its going to be newer.. LS1 is pretty old these days...
My best advice is look at the quality of the work and parts... if its all bolt in.. it's likley not top grade....
If it has a floating rear... it was a serious owner that used it for roadcourse or auto cross...
would require some before during and after mods photos...
Buy a car from someone on Lateral g or PT.com that is known... will get the best quality that way IMHO
Old Nov 12th, 12, 08:01 PM
Chris
Some pics of one I am interested in...
Chris
Old Nov 12th, 12, 08:02 PM
Chris
Chris
Old Nov 12th, 12, 08:03 PM
Chris
Chris
Old Nov 12th, 12, 08:07 PM
Chris
Any advice on questions i should be asking, greatly appreciated.
I'm just not hip to all the upgraded "stuff", don't know the right questions to ask.
Thanks guys
Chris
67speedfreak 67speedfreak is offline
That car doesn't look Pro-Touring ! Other than the engine upgrade.
Please check out my site.
http://www.screaminperformance.net
Old Nov 12th, 12, 08:12 PM
Chris
Thank you, that's what i need. So this is probably just a restoration with a new drivetrain.
I'm ok with that but should i steer clear of the "older" LS1?
Chris
Old Nov 12th, 12, 08:15 PM
Chris
Most important to me is a reliable driver with newer equipment, suspension, etc.
Chris
Old Nov 12th, 12, 08:18 PM
Yes this car doesn't appear to have any brake upgrades or suspension upgrades !
I would go with at least an LS2 if it were me but nothing wrong with an LS1 if it was freshened up with low milage!
  #11
Old Nov 12th, 12, 08:28 PM
Chris
Thanks, sounds good, except I couldn't really know the true milage so it would be a gamble like any used car i guess.
This appears to be put together well, just with stock suspension, right?
Thank you for the input
Chris
  #12
Old Nov 12th, 12, 08:37 PM
Mkelcy Mkelcy is offline
Mike
That car has an automatic transmission - not my first choice for a pro-touring car; the crossover tube in the exhaust looks like it's not actually operational; I can't tell what kind of brakes it's got on the front end - disk or drum; the fuel tank looks like a stocker - don't try to run this car in a corner with less than 1/2 tank of gas.
In short, so far as I can see from the limited picutres, this isn't a pro-touring car.
Mike - '68 Camaro with lots of stuff done to it.
http://imageshack.com/a/img745/1637/0NP8Y4.jpg
  #13
Old Nov 12th, 12, 11:33 PM
Musclerodz Musclerodz is offline
Low budget swap and not cleanly done. I would look elsewhere unless it is real cheap and willing to do some work. Nothing about the car is what I woud define as "pro-touring".
  #14
Old Nov 13th, 12, 06:33 AM
67Rally's Avatar
67Rally 67Rally is online now
Brent
I would keep an eye on the classifieds on pro-touring.com, lateral-g.net and ls1tech.com. And then look for a car that has a build thread, so you can see what's been done, and how well it was done.
You're probably looking for an LS type motor (LS1,2,3,6,7 or LQ4,9, LY6, etc.), T56 trans, tubular control arms(Hotchkis, SpeedTech, DSE, etc) w/ adjustable coilovers, or a full blown PT front clip, 4 link rear, big 4 wheel discs (Wilwood, Baer, C5/6 conversion).
Even if you could just find one with the engine and trans in place, a lot of the other stuff can be added pretty easily. If you don't know what you're looking for check a couple of the build threads on the sites listed above and you'll get a good idea of brands and costs.
  #15
Old Nov 13th, 12, 06:37 AM
67Rally's Avatar
Brent
Aside from the LS engine, new gauges and seats, I agree with the above comments. No suspension upgrades, no brake upgrades, 10 Bolt rear, etc. Keep looking, unless you plan on doing a lot of upgrades to it.
Team Camaro Tech > All Generations > Pro Touring      Current Topic: Advice shopping for Pro Touring Camaro
Location
Location
First Name
Human Verification
