| Team Camaro Tech Current Topic: Muncie speedo | ||
I believe I have a M-20 in my 67' Still decoding, but I need the new plastic gears inside that control the speedo cable. Both are so worn the speedo is jumping. Can someone recommed a good site for parts, and the proper name for the part?
Thanks as usual. G |
| Sponsored Links | ||
Advertisement | ||
Here's a start: I received a manual from Jody's Transmission
Circle gear for the shaft, pencil gear for the speedo.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
There is the Speedo drive gear that is on the shaft and then there is the speedometer driven gear which you can pull out and sits in the bullet/housing which is attached to the cable.
Here is a good resource: http://chevelleengineer.home.comcast...eer/speedo.htm The speedometer driven gear comes in different sizes depending on rear end etc. You can get that from local Chevy dealer, I got one in a day. |
Here is the gear that sits on the shaft:
http://www.thegearbox.org/catalog/it...82/3547889.htm Here is the driven gear that sits in the housing that connects to speedo cable. http://www.thegearbox.org/catalog/it...82/3697857.htm |
Make sure use the correct speedo driven gear with the correct OD corresponding speedo drive gear for longevity.
Jody Haag JodysTransmissions@verizon.net Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations 610-682-1602 Auto Gear Muncie Distributor & Builder My '70 Chevelle: ZZ502/502 ROD 6 Speed |
| Sponsored Links | |
Advertisement | |
