Boots for Original Ball Joints - Team Camaro Tech
Restoration Corner Where originality comes first
Thread Tools Display Modes
Old Nov 17th, 12, 01:37 PM
jeff68 jeff68 is offline
Default Boots for Original Ball Joints
My 68 Camaro has the original ball joints. The car was maintained religiously, so the ball joints are all good. One of the uppers has a cracked boot. For those familiar with original ball joints, I have the following questions:
1) Is it possible to replace just the boots?
I was thinking about buying a set of 'correct' reproduction ball joints made by Classic Suspension, then carefully removing the boots and installing them on my original ball joints.
2) Can a new boot be installed on the upper or lower ball joints without removing the ball joint?
On the uppers, it looks like the boot is held in place with a sleeve. Not sure if I can remove this sleeve without taking the BJ out of the A-arm.
On the lowers, it looks like I could just swap the boots.
So, has anyone done (or attempted) this?
Old Nov 17th, 12, 02:31 PM
camarodude67 camarodude67 is online now
Default Re: Boots for Original Ball Joints
You can replace the boot but you would have to take apart the suspension...and then slip on new boot. I would replace everything with new or just leave it alone.
Jeff G.
Old Nov 17th, 12, 03:01 PM
I don't have a problem taking things apart to replace just the boots. I really don't want to replace the entire ball joint just for a bad boot. I don't want replacement style ball joints, and I believe that the correct style repros are made overseas, so they won't be going on my car!!
Old Nov 17th, 12, 05:10 PM
Right you do not have to take the balljoint off. I'm sending you a pic...
Jeff G.
67 RS Vert
68 L-30 Vert
69 Vert
69 Lm1
69 Z/28 Van Nuys
56 Nomad 409 QB
Old Nov 17th, 12, 07:52 PM
Luwi67 Luwi67 is offline
Bobby
Not sure you can replace the boot on the uppers without removing the factory rivets to get that sheet metal cover off, the one the boot protrudes through.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
https://www.youtube.com/watch?v=1-8uYCabSog
black/black
no radio
Old Nov 18th, 12, 05:57 AM
othal othal is offline
Rick
The metal covers will pry off easily without removing ball joint.
Old Nov 18th, 12, 06:15 AM
I got the pic - thanks. Is that a standard Moog boot on an original lower ball joint?
Old Nov 18th, 12, 06:23 AM
Rick- That would be great. I'd love to be able to change the boots 'in place'.
Have you actually disassembled the ball joints in place? What did you use for replacement boots? Any tips for doing the job? My car is still at the body shop - do you know if the boot on the lower BJ is held on with a sleeve the same way as the upper?
Just looking to get any guidance I can from someone who has actually done the job.
Thanks!
Old Nov 18th, 12, 06:28 AM
Here us a post stolen from CRG to show what the upper ball joints look like:
[quote author=Dusk Blue Z link=topic=3132.msg22546#msg22546 date=1204204594]
Attached is a picture of the different upper ball joints. The left one is a 28K original (mine), the center one is a NOS 3963842 (ebay), the right one is a SS-195 from Classic Suspension (Chevy). The spot welds are very visible on the NOS compared to the original, but the appearance is correct. The SS-195 has a round or bubble top. The rubber boots are held on with the metal band that is shown on the original part.
Does anyone know where you could buy just the rubber boots?
Mike
[/quote]
Old Nov 18th, 12, 07:05 AM
69Z28-RS 69Z28-RS is offline
Gary
Energy Suspension sells replacement rubber boots (Chevy generic).. but they are not too similar in appearance. Hopefully they hold the grease in and water/dust out as I'm using them to preserve my originals (with 'holy' boots)... The boots are available in black color or red.. I bought the black ones, and I'm hoping when the suspension is all assembled, and boots fillled with grease that the difference isn't noticeable.
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
  #11
Old Nov 18th, 12, 09:01 AM
Originally Posted by 69Z28-RS View Post
Energy Suspension sells replacement rubber boots (Chevy generic)...
Thanks for the feedback. I saw those generic boots. I guess I'd rather live with a cracked original boot versus the generic ES boots. I tried a set of ES tie rod boots on my original tie rod ends, but they look awful. I'll swap them out for the correct ones I bought from HBC. That's why I was thinking of sacrificing a set of repro ball joints - at least the boots would be a little more 'correct' looking.
  #12
Old Nov 18th, 12, 09:07 AM
Gary
I've had those same thoughts; and I haven't yet reassembled my suspension, and I may end up doing the same as you describe as well if the ES boots look too 'odd' once assembled.
Gary
69Z28-RS
  #13
Old Nov 19th, 12, 09:42 AM
Update:
I just spoke to Brian Bair at Bair's Corvettes (www.bairs.com).
They have replacement boots for the original upper ball joints, part number 5093 for $6 each. Brian advised that they normally remove the ball joint to replace the boot. He said to carefully remove the ring, then replace the boot & put the ring back on. Unfortunately, they don't have the ring, or boots for the lower ball joints.
I also got a set of the threaded upper ball joint rivets from them, part number 5090C. Brian advised that these are forged, grade 8 strength, and made in the USA.
  #14
Old Nov 19th, 12, 05:33 PM
Rick
I did replaced mine without removing the ball joints. The upper boot has the ring that you pry carefully off the ball joint. Slide the ring over new boot and slip up on the ball joint. The lower does not have a ring. It just slides over the ball joint. Pretty simple job. I actuall had a spare set of ball joints that i robbed the boots from. Don't remember brand.
  #15
Old Nov 19th, 12, 06:19 PM
OK then, I'm going to give it a shot without removing the ball joints. I'll have to perform a better inspection of the boots to see which ones need replacing.
Thanks for your help!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Restoration Corner      Current Topic: Boots for Original Ball Joints
Location
Location
First Name
Human Verification
