69 Front Fender Adjustment - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Nov 18th, 12, 04:54 PM
JGlanton JGlanton is offline
John
Default 69 Front Fender Adjustment
I've been trying to adjust my front right fender to close the gap at the passenger door but I can't get the fender to budge. I've loosened all of the bolts that attach the fender - bottom two, top ones, firewall, the one inside the upper door frame, loosened the radiator support, bumper screws, but it still won't budge. Also unscewed the lower sill trim bracket. What am I missing? Do the door hinge bolts go through the fender? Do I have to loosen or remove those? Do I have to loosen anything in the front valance or header?
Old Nov 18th, 12, 05:19 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Default Re: 69 Front Fender Adjustment
Hinges do not secure the fenders.
Is the mounting point on the firewall touching the firewall? If so that's as far back as it'll go. Were there alignment shims at that point?
Did you loosen the inner wheel well support bracket at both ends?
I'd loosen the header and the valance, but if both ends of the radiator support are loose, everything should shift fairly smoothly.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Nov 18th, 12, 05:30 PM
Sauron67MM Sauron67MM is offline
Scott
You did not mention you touched the inner fender bolts or fender to firewall brace. Look around, you missed something. When everything is loose, simply tightening the fender to firewall bolt will close the gap.
Old Nov 19th, 12, 07:47 AM
reelknots reelknots is online now
Steve
Also take diagonal measurements from the firewall to the opposite side of fender to rad support point to make sure they are the same or close. It may be that both fenders have to shift sideways. This would close the gap on one side and open the other side although not by that much. Just a thought.
Forgot to mention that this would require shifting the rad support sideways on the subframe
69 SS, 350/300 h.p., M-20, 12 bolt, matching numbers.
http://s376.photobucket.com/user/ree...aro%20SS%20350
Old Nov 19th, 12, 09:22 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
I found the bolts on mine were binding in the holes of the fender. The bolt inxide the fender to the cowl was as far back in the hole as it could go. I cut the bracket off the fender and rewelded it with the fender back about 1/4 inch.
Jeff
Old Nov 19th, 12, 02:11 PM
John
Thanks for all the tips, guys. I'll keep cracking at it.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: 69 Front Fender Adjustment
Location
Location
First Name
Human Verification
