Fixing dent in glove box door for an amateur - Team Camaro Tech
Body Shop Paint & Body Forum
Old Nov 20th, 12, 09:57 AM
blue89bird blue89bird is offline
Jason
Default Fixing dent in glove box door for an amateur
What's the easiest way to fix a dent in my glove box door and have it look good after being painted? I've got about a 1" ding in my glove box door. It's not very deep, but very noticeable.
I'm going to be repainted my dash anyway and wanted to get this fixed beforehand. Is this something you can just sand down the paint, apply some filler to, sand, prime and paint, or is it going to show after being painted?
Jason
2010 Camaro 2SS/RS - 1968 Camaro - 2000 Ford Exploder
Old Nov 20th, 12, 10:15 AM
thefley thefley is offline
thefley
Default Re: Fixing dent in glove box door for an amateur
If done right you should not notice. I would go with sand, fill, primer, and shoot.
Oklahoma Camaro Club
www.okcamaros.com
Pics of my 68
Old Nov 20th, 12, 10:43 AM
67CAMARO496 67CAMARO496 is offline
matthew
Sand, fill, prime and shoot.
Old Nov 20th, 12, 11:20 AM
Jason
As long as we're talking about body work, what type of filler is recommended? And what grit(s) sandpaper should I use in order to get this and the dash to look good when painting using an Aerosol can of SEM trim black? What type of primer should be used?
Jason
Old Nov 20th, 12, 12:08 PM
BobKovacs BobKovacs is offline
Bob
Any standard filler should be fine- I've been using Evercoat, and it goes on smooth and sands well. When I did my firewall with SEM Trim Black, I did the filler work, primed it with two coats of epoxy, scuffed that to 180 grit, and then shot the SEM. You may want to go finer, like 320, and epoxy is probably overkill, but a good primer sealer is a must.
Old Nov 20th, 12, 12:20 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
What about taking it to Paintless Dent Repair? Maybe they'll knock it out for you for nothing seeing as how it's so small.
http://www.dentwizard.com/Locator.aspx?state=NJ
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Nov 20th, 12, 12:35 PM
Jason
From what I've seen, they can only get dents out if they can reach behind it somehow, or else they drill a little hole and then put a plug in it. I don't want a hole and I don't see how they could get behind where the dent is.
Jason
Old Nov 20th, 12, 12:49 PM
camaroman7d camaroman7d is offline
Royce
Glove box door is no different than any other body panel as far as filling a dent/ding. If you have never done it before the chances of it coming out "unoticable" is probably pretty slim. I would much rather have a small hole drilled behind it (where you will never see it) rather than attempt a repair and have it come out bad. How deep is the "ding" if it's an inch diameter it is a dent not a ding in my book.
To do it 100% corrct I would strip the door to bare metal, put a couple coats of epoxy on it, do your body work (fill work), them prime with your coice of primer, sand to remove all scratches, etc... then paint.
If you are doing a rattle can restore on the dash then depending on how deep the ding is you may be able to get away with a scuff and some glazing putty. Hard to say without knowing exactly what the damage looks like and what your plans are.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
(brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers)
Old Nov 20th, 12, 01:15 PM
HwyStarJoe's Avatar
I didn't think about not being able to get behind it....
SEMA ACTION NETWORK
Old Nov 20th, 12, 01:28 PM
rojo rojo is online now
Robert
Yeah those paintless dent remover guys can only do their magic if they have something to pry against. Had a dent in the fender of the '67 and I raised the hood to show the guy all the access between the inner fender and fender. He said that wouldn't work then proceeded to drill a hole in the inner fender to place his tool from the tire side to apply leverage (with my permission of course).
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old Nov 20th, 12, 03:34 PM
code 55 69 code 55 69 is offline
Tech Team
Bob
I would suggest, sand it down with 150 grit, apply skim coat of filler, sand down to as level as you can,finishing off with approx. 200grit, hit it with a sandable filler primer, wet sand it with 600 until it is smooth as glass, make sure all fine scratches are gone, reprime & then paint using SEM satin or marque black...hope this helps
Old Nov 20th, 12, 07:05 PM
67Carl's Avatar
67Carl 67Carl is online now
Carl
There's a post in the archives where someone painted their glove box door that got me motivated to do it. I used rustoleum rattle can primer and paint (semi gloss black) bought from Home Depot as the guy did in that post. No dents but some deep scratches. I figured if I sanded them well enough I wouldn't need filler. I was wrong. I started with 80 and ended with 800 wet and you can still see remnants of the scratches, so use filler. Rattle can not necessarily the best but you can only see lines under certain light conditions and you have to really be looking for it. No pics of finished door but a few in process...
Click image for larger version
1967 350, Hurst TKO 600 5 speed, 12 bolt 3:55 posi, RS added
http://photobucket.com/1967_Camaro_Carl
Gone but Not Forgotten: 1970, born with a 6cyl, 350sbc transplanted in
http://photobucket.com/Carls1970Camaro
Last edited by 67Carl; Nov 20th, 12 at 07:07 PM. Reason: Tried to rotate image, can't figure it out. Door is hanging by string from rafters...
Old Nov 20th, 12, 07:38 PM
rockin rollin rockin rollin is offline
why not save yourself all that darn work? and try to one on e-bay that looks good. seem alot for sale there.
Old Nov 21st, 12, 05:06 AM
HwyStarJoe's Avatar
I tried the same thing on mine Carl. I ended up stripping it down to metal.
SEMA ACTION NETWORK
Old Nov 21st, 12, 05:21 AM
Jason
the more i think about this, the more likely I am to just spend the $75 or whatever and get a brand new one.
Jason
