| Team Camaro Tech Current Topic: 434 SBC with AFR 245 heads on dyno | ||
| Sponsored Links | ||
Advertisement | ||
What time is it
. OMG! I've been watching that sweet motor since before dinner time.
One owner 69 Camaro,(yep, bought it new )RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers. TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60' All with 1960's stuff. (except tires and converter) + MT Super Scavenger headers. 1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too. ![]() http://epitomesrebuild.com/ |
Haven't been on here in a long time, been on YellowBullet since it's mostly drag racing. Sat out this entire year so I could get this engine built.
2013 is going to be really fun. Low 9's I'm hoping... ![]() If you want more detail you can read here: http://www.yellowbullet.com/forum/sh...d.php?t=523288 |
wow! what are all the specs?
69 Camaro 406sbc ALL MOTOR 1.43 6.68@99.00 Full weight street car driven to track on pumpgas |
1969 Camaro 434 SBC Engine Specs:
Block: Dart Little M with 4-bolt splayed steel billet main caps Crank: Callies Dragonslayer 4” stroke Rods: Manley H-beam 6” with ARP 2000 bolts Pistons: Wiseco #K404A3 10cc dome 4.155” dia. 60/40 spacing Ring Set: Total Seal Plasma Moley Bearings: Calico Coated (Cam, Rods & Mains) Lifters: Crower .842” dia. with .180I/CenterE offset Mechanical Roller cam specs: Lobe lift Intake & Exhaust: .455” Duration @ .050 lift: I:278 / E:288 Intake 1.7 rockers: .774" Exhaust 1.6 rockers: .728" Lobe Center: 109 Rocker Arms: Jesel shaft rockers with .450I/.100E offset Heads: AFR 245cc CNC NPP Valves: 2.125I/1.60E Springs: PAC #1225 Retainers: 10° Titanium Locks: 10° Steel Pushrods: Manley 5/16” .120 wall thick Compression Ratio: 14:5 Intake Manifold: Edelbrock #2970 Carburetor: Holley Ultra 1050 Dominator Fuel System: Aeromotive A1000 pump & return style regulator Distributor: MSD #84697 Crank Trigger: MSD #8610 Coil: MSD #8251 Ignition Box: MSD #7531 Spark Plugs: NGK #R5672A-9 Headers: Hooker Super Comp 1-7/8” Head Gasket: Fel-Pro #1014 Intake Gasket: Fel-Pro #1207 Exhaust Gasket: Fel-Pro #1405 Calvert Racing suspension, CalTracs, split mono rear springs Rancho 9-way adjustable rear drag shocks & 90-10 shocks up front with Unisteer Rack & Pinion Transmission: Powerglide with a full forward pattern & Hughes Pro Tree Brake Axle: GM 12-bolt, with Moser 33 spline axles, 4.33 gears on a Moser spool & C-Clip eliminators Wheels: Weld Pro Star 15”x3” front & 15”x8” rear Tires: MT 28”x10.5”x15” Radiator: Griffin 700hp rated aluminum with Zirgo 3000cfm electric fan Aerospace drag racing front disc brakes Car weighs 3000lbs. |
Should be enough to embarrass more than a few big blocks
Please post some times when ya get it to the track Good Luck
68 originally ss (straight six) 406,Afr210,Bullet solid roller,rpm airgap,QF750,th400,3.73 Eaton posi.11.3@118 |
Awesome motor, but a built up big block will not be embarrassed. Just sayin. Do not want to start a war big vs small block. I love small blocks but big cubes are tough to beat.
Still needs an 8.50 cage, mini tubs, Strange Ford 9" |
Damn. That's crazy.
I did a sbc 406 in a 69. Never knew anything about them. Bought the 350/350 car from a guy to do an LS swap. When I ran the casting found out it a sbc 400. Did a little research and decided to keep it. Budget built it 5.7 rods 10.1 with Alum heads and Howard flat cam. I was amazed at how well it runs
69 Pro Tour - LS7/T56 Building ![]() C6ZO6 Vette Lemans Blue 69 Z28/RS Tribute 355/5 Speed(SOLD) 69 RS Clone 427/TH400(SOLD) 67 RS ZZ502/5 Speed(SOLD) 69 Camaro 406 SBC/TH400(SOLD) |
#11
My next build for sure
#12
Very nice. Killer motor!
#13
Little M 434 SBC with Juice in the works |
#14
lol
#15
great job you should get that outa it-alots better than my stock block 434
| Sponsored Links | |
Advertisement | |
