Engine Stamp number for 1969 Camaro - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Nov 26th, 12, 02:57 PM
cadmanof50s's Avatar
cadmanof50s cadmanof50s is offline
Vic
Default Engine Stamp number for 1969 Camaro
Just purchased this 350 block for a rebuild.
I was told it came from a 1969 Camaro.
I checked out the casting number and the suffix part of the stamped engine number and they seem to confrim that it was from a 1969 vehicle.
Casting 3932388
Suffix T0927HQ
But the serial number part of the stamped number does not make sense for a Camaro.
I read it as 791102916.
This does not appear correct for a 69 Camaro engine number.
Can someone please help me decipher the number.
Pictures attached.
Thanks!!
Vic
Click image for larger version
ID:	31101   Click image for larger version
Vic Brincat
1968 Camaro RS Convertible
On Deck: 383 SB, AFR 195 Heads, 670 Holley, Doug Thorley Tri-Y Headers, Lunati "Voodo" roller cam, Weiand 8150 Intake, Scorpion Edurance Rockers, 700r4, Eaton Posi with 3.73 gears, Front Discs, Summit Legend 5 - 15" with BF Goodrich TAs
Old Nov 26th, 12, 03:14 PM
Jammincamaro Jammincamaro is offline
Gary
Default Re: Engine Stamp number for 1969 Camaro
It should read 19Nxxxxxx or 19Lxxxxxx
69 Z28 x77 10 10 B
http://i960.photobucket.com/albums/a...1252E5C5F7.jpg
Old Nov 26th, 12, 03:19 PM
Vic
Thats what I thought too Gary.
But there is no way this number is a 19Nxxxxxx
The 7, 9 and 11 could possibly be destorted and it may be 19N, but there are only 5 digits after this not 6.
BTW, not sure if it helps....it is a 4-bolt main block
Vic
Vic Brincat
Old Nov 26th, 12, 03:23 PM
Gary
Yes I agree I scrutinized your pic
It's not from a camaro IMO
Maybe one of the experts can chime in ?
69 Z28 x77 10 10 B
Old Nov 26th, 12, 03:41 PM
Vic
Just putting things together from what I have read on other sites, it appears that Chevy's had a specific format for their engien number
a two number code, a letter and the a 6 digit number. With that in mind, this number may be read as:
7 (or a 1) 9 I (as in Indiana) 102916
79I102916
Does that make sense.?? but definitely not Camaro in that case/
Vic
Vic Brincat
Old Nov 26th, 12, 03:43 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
Not from a Camaro.
Probably an LM1 from a 1969 Canadian Built Chevelle from what I can tell.
HQ is 350/255hp used with manual 3 speed or 4 speed transmission. Used in Camaro/Nova/Chevelle.
In this case the vehicle assembly plant digit appears to be a 1 - which is Oshawa, Ontario, Canada. There weren't any Novas or Camaros built there, so it is from a Chevelle.
7 - ? maybe a mistake and should have been a 1
9 - 1969
1 - Oshawa vehicle assembly plant
102916 - last 6 digits of VIN it was installed in
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Nov 26th, 12, 03:49 PM
bertfam bertfam is offline
Ed
I believe it's from a 1969 full size car assembled at the St Therese, Canada plant.
1 - Chevrolet (looks like a 7, but skewed. Really a 1)
9 - 1969
1 - St Therese, Canada (Oshawa was 0 until 1970, then they changed to 1)
102916 - Sequential serial number
However, the HQ "supposedly" wasn't used on the full size cars in 1969, but there were other codes also "supposedly" not used that have been verified.
I'll see if Warren can shed any light on this.
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
My Home Page
My contact info
Camaro Research Group
Old Nov 26th, 12, 04:00 PM
lcmc lcmc is offline
Danny
Originally Posted by bcm66 View Post
Not from a Camaro.
7 - ? maybe a mistake and should have been a 1 ?
9 - 1969
I thought HQ was 350 300hp
Old Nov 26th, 12, 04:08 PM
bcm66's Avatar
Bryon / Big B
Nope. HQ is 350/255 hp used for LM1.
Here is a VIN plate from an Oshawa built 1969 Chevelle.
Old Nov 26th, 12, 04:19 PM
Danny
Not according to this. HQ is 300hp
http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php
Old Nov 26th, 12, 04:21 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
Hum I thought early 69 model year 350's cast in late 1968 were only stamped vin wise on the pad, and the so called late model year castings done in calendar 1969 were stamped all at the oil filter. What is the cast date of this block?
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old Nov 26th, 12, 04:48 PM
bcm66's Avatar
Bryon / Big B
Originally Posted by lcmc View Post
Sorry but that site is WRONG.
Old Nov 26th, 12, 04:51 PM
bcm66's Avatar
Bryon / Big B
This is an early block, based on the engine assembly date and partial VIN.
And it is possibly a rare one. I am checking with a friend who is a Chevelle expert. I will report back when/if I find out anything.
Old Nov 26th, 12, 05:33 PM
BARRY A BARRY A is offline
BARRY ALLAN
7 is pontiac
Old Nov 26th, 12, 05:54 PM
Vic
Thanks for all the input.
It is interesting to know what this came out of.
Just to be clear, I purchased it because the suffix code and casting indicates that this is a 69 block. Which I think we all seem to agree it is. (Bummer that it's not a Camaro). Also because it is a 4-bolt.
I'm intending to use it as the block for my 383 build and chose this particular block because of the year and because it seems to be in excellent shape.
Although it will be going into a '68, the vintage is close enough for what I want to accomplish.
Thanks for the help and ongoing posts.
Vic
Vic Brincat
