New springs came in today have top and bottom question - Team Camaro Tech
Old Nov 27th, 12, 07:22 PM
joels's Avatar
joels joels is offline
Team Member
Joel
Default New springs came in today have top and bottom question
2'' drop Belltech springs arrived today, opened box to look at and I did not see any marking for top and bottom. There does not seem to be any difference but before I install Sat is there a difference?
Old Nov 28th, 12, 07:22 AM
77thor's Avatar
77thor 77thor is offline
Fred
Default Re: New springs came in today have top and bottom question
Usually there is a difference. For instance Hotchkis drop springs need to be installed so that the Hotchkis brand name sticker is right-side up.
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Nov 28th, 12, 08:30 AM
Everett#2390's Avatar
<Jake 68's Rule
Springs usually come with a flat end, called closed end, and the other end is open end, as in not flat.
Set the spring on the floor, if it leans, the end sitting on the floor goes into the lower control arm.
The flat end goes up into the frame pocket.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Nov 28th, 12, 10:20 AM
joels's Avatar
Team Member
Joel
They do not have flat ends, I will try the standup method this evening when I get home.
Old Nov 28th, 12, 10:28 AM
BobKovacs BobKovacs is offline
Bob
Have you called Belltech and asked them which end is up?
Old Nov 28th, 12, 12:36 PM
joels's Avatar
Team Member
Joel
Just did and feel stupid since. I opened them last night not so good light. Called them they said turn the spring where you can read the Company name and part number. That is top
Old Nov 28th, 12, 12:48 PM
Bob
Well, at least you didn't install your sway bar upside down like the guy in the other thread, even though the Hotchkis sticker was right there upside down in plain sight....lol
Old Nov 28th, 12, 01:02 PM
joels's Avatar
Team Member
Joel
I saw that, I guess your right
Old Nov 28th, 12, 01:18 PM
<Jake 68's Rule
Default
One would have thought they would have printed the instruction "This end up." somewhere on the box or put an 'UP' arrow on the tag.
Old Nov 28th, 12, 02:16 PM
joels's Avatar
Team Member
Joel
I went ahead and put blue tape on top just in case I can't read Thu am when I start the install.
Old Nov 28th, 12, 02:41 PM
jcfcamaro jcfcamaro is offline
jared
I wonder how many times the hung over factory worker puts the sticker on wrong !!! I would think there has to be a better way of telling. I work for Eaton Corp the worlds best truck transmission maker, and screw ups do happen .
Old Nov 28th, 12, 03:07 PM
joels's Avatar
Team Member
Joel
If that happens and after the install there is going to be a hung over installer too
Old Nov 28th, 12, 03:38 PM
rojo rojo is offline
Robert
You would think this would save them some phone calls. Hotchkis makes it worse by putting some abstract number that does not come close to their catalog part number. This leaves you wondering if you got the right part.
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
