Converting PG to Muncie: Neutral safety switch and reverse lights - Team Camaro Tech
Old Dec 5th, 12, 05:25 PM
blue89bird blue89bird is offline
Jason
Default Converting PG to Muncie: Neutral safety switch and reverse lights
What's the easiest way to do this? I'm probably going to be replacing the dash harness first. Should I purchase a MT harness? If so, are they any pictures of how the NSS and Reverse switch mount? I've done some digging but can't seem to find anything.
Thanks,
Jason
Jason
2010 Camaro 2SS/RS - 1968 Camaro - 2000 Ford Exploder
Old Dec 5th, 12, 06:03 PM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: Converting PG to Muncie: Neutral safety switch and reverse lights
On starter purple wire to purple/white wire, just jumper them together with a 1/4 inch wide male-to-male bullet - see assortment pack at your local parts store.
OE design reverse light switch is mounted on trans and actuated by linkage from reverse lever. I made one from a metal coat hangar. Rev switch does have a two-wire male plug/harness mating to a female connector next to the gas pedal. with a harness on the top drvr side trans bolt to bellhousing.
Inside dash, white wire is connected to ign power and green wire to rev lights.
Or, if you get a Hurst shifter, you might get a Hurst back-up switch.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Dec 7th, 12, 05:41 AM
Jason
Thanks Everett. So if I understand this correctly, the OEM reverse switch mounts on the trans and is activated by a rod from the reverse lever on the trans. There is then a plug that connects to the existing harness inside the car. For a car that's originally an automatic, is there an existing hole in the firewall somewhere to run this harness, or does it have to be drilled?
Jason
Old Dec 7th, 12, 07:26 AM
<Jake 68's Rule
You're welcome. I do love Ping - cut & paste an image/screen and transfer to Word doc.
Hole should be punched, Greenlee style/brand,rather large, 1/2 inch, at least rather than drilled.
Yes, switch with its harness bolts to a bracket and bracket bolts onto the lower right two cover screws and a rod links the lever to the switch.
Click image for larger version
Old Dec 7th, 12, 07:46 AM
Jason
Thanks! I really need to figure out how to find stuff in the Assembly manual which I have sitting in front of me because I looked for 10 mins then got frustrated and posted here.
Jason
Old Dec 7th, 12, 08:26 AM
<Jake 68's Rule
If the item you're looking is not in the general front sections, UPC1 through UPC XX, as in a Plain Jane Camaro, look in the Option Index.
