Muggy Weld ?? - Team Camaro Tech
Body Shop Paint & Body Forum
Old Dec 6th, 12, 10:55 AM
67 455 Bird ragtop 67 455 Bird ragtop is online now
Team Member
Mark
Default Muggy Weld ??
Anyone ever use this stuff?? I was considering using it to weld some aluminum mounting brackets onto my aluminum radiator.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
http://community.webshots.com/album/222472397caZdha
Old Dec 6th, 12, 12:30 PM
Luwi67 Luwi67 is offline
Bobby
Default Re: Muggy Weld ??
Looked at their site. Seems like it's brazing. I guess it couldn't hurt since their materials will liquify before your radiator to avoid burn through.
If the bracket breaks afterwards then you could always have it tig welded and come away with some good first hand info.
67 Camaro 350
M20 4spd console,
8.5 30 spline Eaton posi,
Moser shafts, Richmond 3.73
custom Spintech exhaust
black/black
Old Dec 6th, 12, 02:05 PM
Team Member
Mark
True. My plan is to do a test with similar gauge aluminum and see how well it does hold together and how easily it works. A friend has a similar product called Dura-Fix he was going to let me try. Says it works pretty well also. But you need to make sure you have a clean surface unlike the Muggy Weld. I'll post back any test results.
Old Dec 7th, 12, 05:40 AM
18436572 18436572 is offline
Make sure that your radiator is welded and not "glued" together.
A friend bought a griffin a few years back and We were going to have some tabs welded on, then noticed that the tubed were epoxied to the side tanks.
We called griffin and they said do not apply heat to the tanks or it could damage the epoxy.
Bill
Old Dec 7th, 12, 06:10 AM
Team Member
Mark
Thanks for the tip. Mine is a Griffin. I thought all Griffins were welded??? But after a little research you are correct. They are all epoxied. THANKS!!!!! guess I'll look into other options.
