Restore a German Race Camaro Engine - Team Camaro Tech
Camaro Tech General Tech Area
Old Dec 8th, 12, 06:40 PM
psy4s's Avatar
psy4s psy4s is offline
Team Member
Christopher
Default Restore a German Race Camaro Engine
It has been a while since I was able to work on my car. After my company gave us the heave ho, I had to give it a go as my own company again. My Camaro set idle for most of a year, but I have started working on it again.
The reality is that my car was a Race car in Europe fro many years before I bought it. As a race car the body was torn and burned, with cracks, and holes burnt into every part of her. It was over a year on the rotisserie bringing the body back to the way it was the day it came from the factory.
The engine is not the same story. I wanted to keep to the history of the car. I wanted to keep enough performance under the skin, to give the car the ability to go back to the Nuremburg Race track, and hold it's own.
Follow my build here:
http://www.camaros.net/forums/showthread.php?t=176064
Balanced 350, Eagle rotating assy, Mahle Flat top Forged pistons, AFR 195 cylinder heads, AFR Hydrorev kit, Comp Cams Hydraulic Roller Cam, comp Pro Mag Ultra Roller Rockers, Edelbrock AirGap RPM Manifold.
Live to rev!
Old Dec 8th, 12, 06:48 PM
psy4s's Avatar
Team Member
Christopher
Default Re: Restore a German Race Camaro Engine
This is what it had when I bought it in 1985.
I assembled it in my Dorm room at Lindsey AS Germany, in Wiesbaden, using ordered parts from PAW. (Remember them?)
Live to rev!
Old Dec 8th, 12, 06:56 PM
psy4s's Avatar
Team Member
Christopher
I brought her home in 1987 to Indiana. Off to Motsingers Machine shop, and I put together a real Beast of a Motor for a 327.
Live to rev!
Old Dec 8th, 12, 07:15 PM
b17brian b17brian is offline
Tech Team
Good looking engine. When will it go back in? Curious why your engine bay is red?
'67 SS/RS, 350ci, Muncie M20
http://s1355.photobucket.com/albums/q713/b17brian/
Old Dec 8th, 12, 07:25 PM
psy4s's Avatar
Team Member
Christopher
Now that I have started the restoration I wanted to find an engine that fits my car. It is a real 4P car, with a race history. I found a 1992 Chevy 4 bolt truck block with a one piece rear main. It was a low mileage block with STD bore. This was a perfect place to start. I designed just what I wanted, then started collecting parts.
Mahle Forged pistons, Eagle H-Beam connecting rods, Eagle Forged crank, Comp Cams Extreme Roller cam, lifters, and Pro-magnum Double roller rockers, Comp Cams Double roller timing chain, the cherry on top is a set of performance AFR 195 cylinder heads.
Live to rev!
Old Dec 8th, 12, 07:35 PM
psy4s's Avatar
Team Member
Christopher
The block was cleaned, Line bored to .030 over, the crank studs installed, and the mains line honed. The cylinders were Torque Plate honed, and a coat of Chevy Orange paint.
Live to rev!
Old Dec 8th, 12, 07:53 PM
psy4s's Avatar
Team Member
Christopher
While this was being done, my cylinder heads arrived. My co-pilot's face says it all,
I opted for the Titanium retainers to lighten the valve train.
Live to rev!
Old Dec 8th, 12, 08:20 PM
psy4s's Avatar
Team Member
Christopher
Live to rev!
Old Dec 8th, 12, 08:27 PM
psy4s's Avatar
Team Member
Christopher
Live to rev!
Old Dec 8th, 12, 08:31 PM
psy4s's Avatar
Team Member
Christopher
Live to rev!
Old Dec 8th, 12, 08:34 PM
psy4s's Avatar
Team Member
Christopher
Well, It is ready to run. Once I get the Trans, and the fuel system together, it all goes in. I will update this then.
Live to rev!
Old Dec 9th, 12, 03:57 AM
buenymayor buenymayor is offline
Looks good, Chris. I was thinking just the other day we hadn't heard out of you in a while. Glad to hear you're still making progress.
Experience...... It's what you get when you didn't get what you wanted.
http://camaro.bertke-one.com/teamcam...%20Camaro.html
Old Dec 9th, 12, 04:23 AM
DOUG G DOUG G is offline
RedЯuM
Looks good so far
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Dec 9th, 12, 04:28 AM
SixtyAte's Avatar
SixtyAte SixtyAte is offline
Kevin
Great build!!!
Keep us posted....
Kev
Old Dec 9th, 12, 02:27 PM
jcfcamaro jcfcamaro is offline
jared
Looks very nice, and looks like we have a upcoming gear head drooling on the new arf heads. I bet he can't wait to drive it !!
