Sway Bar Install - Team Camaro Tech
Old Dec 9th, 12, 06:17 PM
sierra1boy sierra1boy is offline
Default Sway Bar Install
Hey guys,
So I've installed the Hotchkis TVS on my 68 and ended up screwing up and installing the sway bar upside down. I removed it this weekend and tried to re install it the right way, however, I can't get it feed in no matter which way I try to feed it through. Is there a trick to installing these? What has to be removed to get in?
Old Dec 9th, 12, 06:40 PM
67Dale 67Dale is offline
Tech Team
Dale
Default Re: Sway Bar Install
On my 67 I had to remove the spindle and coil spring on one side to fit it through. I have a 1 1/4 inch front from PST. Could not get it in without removing the spindle.
67 RS Camaro
71 SS Nova
68 Chevelle
Old Dec 10th, 12, 09:36 AM
BPOS BPOS is offline
Al
http://www.hotchkis.net/_uploaded_files/2207F.pdf
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Dec 10th, 12, 09:26 PM
I tried this procedure several times and I still can't get it all the way through. Are there subtle differences in some of these frames where this procedure won't work for all 68 Camaros?
Old Dec 11th, 12, 04:09 PM
69CamaroRT 69CamaroRT is offline
Robert
i just did this and mine went right in, no problems at all. of course, my engine is out making it a breeze. with the tires still on, i just jacked up the passenger side of the car and turned the wheel to the drivers side and it went right in. no diffference in the frames between the 3 years. you might have to remove the harmonic balancer for a little more room as the balancer is right above the sway bar. also jack both front wheels and remove the wheels. like said, you may have to remove the coil spring on one side. or, remove the engine and it will go right in. sometimes it take a little patience.
69 Camaro Z/28 RS 10A of 68. 50 S with 723 int. soon to be 302 with m21. BU 12 bolt posi. http://s190.photobucket.com/albums/z...view=slideshow
Old Dec 11th, 12, 04:25 PM
thefley thefley is offline
thefley
Had installed mine but had tubular control arms, so I had to drop lower a-arm down to feed it in.
Oklahoma Camaro Club
www.okcamaros.com
Pics of my 68
Old Dec 11th, 12, 08:54 PM
davidpozzi davidpozzi is offline
David Pozzi
I've done a bunch of small block & LS engined bar installs & only had to pull the RF wheel, no hammers. A big block might be tougher.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Dec 12th, 12, 09:12 PM
ROBS6T8's Avatar
ROBS6T8 ROBS6T8 is offline
Robert
When I first installed my Hotchkis swaybar, i just fed it through without removing anything. It took me forever to get it in and I scratched the heck out of it but it went in. After replacing the front suspension, and not putting the swaybar in first, I tried to get the swaybar back in and it wasn't going! I couldn't for the life of me figure out how I got it in before. I had to remove a coil spring to get it in the second time.
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread http://www.camaros.net/forums/showthread.php?t=180476
Old Dec 12th, 12, 10:24 PM
Fred Ficarra Fred Ficarra is offline
Fred
Hell of a job. When I did it in 69, it was to install my Addco 1" bar. All those memories are now a nightmare but it must have been OK. The paper part number is still on the bar. Whew.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
