| Team Camaro Tech Current Topic: Need a little help | ||
| Restoration Corner Where originality comes first |
I have done a search on the site, and I have an assembly manual but it does not have everything in it. I am looking to get a book on every part that my car has or had on every level. I want an exploded veiw that way I will know what I am missing as far as screws parts etc... I have heard of the fisher book and the maintenance books. I guess what I am asking is there a book out there I can get that has everything or will I need to get the other two??? My car needs EVERYTHING on the interior. I am wanting this so I dont leave out anything I will need as far as parts go. Plus the names of the parts. This is my frist time around on this 68 and I want to do it right. Thanks for any help
| Sponsored Links | ||
Advertisement | ||
Here's the tread that should help you find what you need:
http://www.camaros.net/forums/showthread.php?t=192224 |
I have the factory assembly manual. I did not see a Fisher manual or the service manual for a 68 in that thread.
Sorry, you're right. I didn't realize that the others were there for '67 but not '68.
There is NO one book that I know of and most of us have the AIM, Fisher Body Manual, etc....
An index I made up to help me find things in my 68 AIM. 1968 CAMARO FACTORY ASSEMBLY INSTUCTION MANUAL (AIM) TABLE OF CONTENTS UPC 0 - General Information UPC 1 - Body and interior/exterior trim and hardware UPC 2 - Frame UPC 3 - Front suspension UPC 4 - Rear suspension & prop shaft UPC 5 - Brakes UPC 6 - Engine UPC 7 - Transmission & clutch UPC 8 - Fuel & exhaust UPC 9 - Steering UPC 10 - Wheels & tires UPC 11/13 - Front sheet metal, radiator & grille UPC 12 - Electrical UPC 14 - Bumpers & miscellaneous 396 Engine Related- Pages 272-290 & 298-303 4-Speed Trans Back-up Switch- Page 323 & Transmission Mtg. to Cross-member- Page 95 4-Speed Trans Shifter Adjustment- Page 321 4-Speed Trans Shifter Assy. to Trans. & Cross-Member-Page 320 4-Speed Trans Shifter Rods & Hardware-Page 318 4-Speed Trans Shifter Rods & Hardware Big Block-Page 319 4-Speed Trans Shifter Stabilizer Shafts (3 of them)-Page 320 Accelerator Pedal & Parts-Page 103 Accelerator to Carb-Page 105 Accelerator to Carb Linkage & Hardware Z/28-Page 441 Air Cleaner to Carb & Valve Covers Z28-Page 443 Alternator Brackets Z/28-Page 441 Alternator Mounting-Page 79 Axle U-bolts-Page 243 Battery & Battery Cables-Page 151 Battery Tray-Page 149 Brake Line & Emergency Brake Brackets-Page 243 Brake Line-Front-Page 72 Brake Line-Rear-Page 73 Brake Pedal-Page 71 Brake Pedal Stop Lamp-Page 166 Brake-Master Cylinder, Brkt., & Pressure Indicator Switch-Page 70 Bumper Front/Rear Assy-Page 178/179 Bumper Guards Front&Rear-Page 419 Carpet-front-Page 47 Cigarette Lighter-Page 165 Clip closure-non hardened steel-Page 5 Clutch Linkage Adjustments-Page 114 Clutch Pedal & Linkage-Page 112 Clutch Release Bearing-Page 111 Clutch Shaft & Push Rod-Page 113 Console-Floor Assy-Page 229-231 Console Gauges-Page 385 Console Oil Gauge Line Routing-Page 386 Control Arms-Page 59 Cotter Pin Install Instructions-Page 5 Cowl Panel Piercing-Page 9/10 Cowl Seal-Page 136 Cowl Vent Grille-Page 37 Dash Trim Plate-Page 44 Dash Insulator Pad/Mat-Page 40 Defroster Ducts-Page 53 Disc Brakes-Front-Page 247 Dual Exhaust & Muffler-Page 360-367 Engine Mounts to Sub-Frame & Engine-Page 94 Exhaust Muffler & Hangers-Page 119 Exhaust Pipe (rear) & Hangers-Page 118 Fan Shroud & Radiator-Page 145 Fender Assy-Page 135 Fender Emblems-Page 139 Fender Extension to Fender & Valance-Page 143 Fuel Pump-Page 99 Fuse Panel-Page 160 Gas Cap Assy & fit up note-Page 121 Gas Gauge Metering & Rear Hose-Page 124 Gas Line & Clips-Page 123 Gas Tank Filler Neck (lower) & Cover-Page 122 Gas Tank Mtg. & Straps-Page 121 Glove Box Assy-Page 41/42 Grille-upper, lower, center & emblem-Page 138 Header Panel-Page 137 Headlamp-Page 153 Headlight Switch-Page 165 Headlight Dimmer Switch-Page 166 Heater Control Assy-Page 55 Heater Control Cables-Page 56 Heater/Defroster Assy-Page 52 Heater Fan, Blower Assy/Cowl-Page 52 Hood Catch, Support, & Latch Assy-Page 144 Hood Hinge-Page 136 Hood Insulation & Retainers-Page 448 Horn Relay-Page 155 Hub Assy-Page 60 Ignition Switch-Page 92 Inner Fender Mtg-Page 141 Inner Fender Seals-Page 140 Instrument Cluster/Instrument Cluster Lighting-Page 161/162 Instrument Panel Wiring Harness-Page 163/164 JL8 Brakes-Page 243 Leaf Spring to Front Bracket/Leaf Spring to Axle & Rear Shackle-Page 66/67 Master Cylinder Assy & Balance Valve-Page 248 Mirror-Rear View-Page 44 Mirror-LH Door-Page 40 Motor Mounts-Page 94 Nut install that are open end type stamped 'MB'-Page 5 Parking Brake Alarm-Page 168 Parking Brake Connector & Rear Cables-Page 75 Parking Brake Pedal-Page 74 Parking Lamp-Page 153 PCV & Hose Z28-Page 443 Pedal Trim Plates-Page 438 Power Brake Assy @ Cowl-Page 245 Power Steering-Page 373-379 Radiator support to fender & fender support rods-Page 142 Radiator & Clutch Fan-Page 256 Radiator & fan shroud-Page 145 Radio Antenna-Front-Page 410 Radio Capacitors-Page 406 Radio Ground Straps V8-Page 408 Rag Joint assy & Caution-Page 129/130 Rear License Lamp-Page 172 Rocker Panel Sill Moulding Spears-Page 45 RS Related-Page 423-437 Sheet metal gaps-Page 146-147 Shock Absorber-Front-Page 61 Shock Absorber-Rear-Page 68 Side Marker Lamps-Fender-Page 154 Smog Pump Z28-Page 442 Spare Tire & Jack Storage-Page 132 Speedometer Cable 4-speed-Page 241/322 SS Hood & Emblems-Page 294 SS Paint Stripes-Page 295 Starter Motor Mtg.-Page 89 Steering Box to Column Assy-Page 127 Steering Column Bolt-up-Page 44 Steering Column to Dash Seal-Page 128 Steering Column Mandatory Install Sequence-Page 130 Steering Wheel assy Sequence-Page 129 Sub-Frame Body Mounts-Page 50 Sway Bar & Links-Page 62 Tic-Toc-Tach-Page 384 Tie Rod Assy-Page 126 Transmission 4-speed Cross-member Mount-Page 95 Valance to fender & fender extension-Page 143 Ventilation System/Dash-Page 51 Voltage Regulator-Page 92 Windshield Motor Switch-Page 42 Windshield Washer Jar-Page 38 Windshield Washer Nozzle & Hose Rtg.-Page 39 Winshield Wiper Motor, Arm, & Linkage-Page 36 Windshield Wipers-Page 37 Wiring-Alternator, Regulator & Relay-Page 156 Wiring-Floor Console-Page 233 Wiring-Console Gages Eng. Compartment-Page 386 Wiring-Courtesy Lamps-Page 167 Wiring-Engine V8-Page 158 Wiring-Headlamp, Park Lamp, Junction Block & Horn Relay-Page 155 Z/28 Paint Stripes-Page 444/445
Chick 07 Z06 Corvette 67 L89 Corvette Conv. (Tribute Project) 68 L68-Corvette Conv. Orig Engine/Drivetrain 68Z28-Orig. Engine/Drivetrain 69Z28-Cross-ram Orig Engine Resto-Mod 69SS396 Nova-L34 Father/Son Owned 76 TR6 w/13,000 miles |
I have the 1946-1972 chassis and body parts manual as a pdf but I don't remember where I got it. I just did a google search for those key words including pdf and found even more. The parts manual has blown up pics of many assemblies.
Thanks for the list Chick. I was wanting a book or PDF mainly for reference and not putting something in first and then have to turn right around and take it back off. Mainly the interior, and A/C heater stuff. That and for a parts guide to buy from when I need something. I will have my hands full with the wiring as its going in new as well.
Thanks Mike, I will try that and see what I can find. And thanks again for the replys guys every little bit is gonna help. |
I would follow this route, unless another member has another idea:
Install electrical harness, courtesy lights, etc., then build dash from the firewall toward the inside, Install headliner and visors, Install weatherstriping, regulators and glass, doors included, Install side panels, handles, etc., Install carpet, kick panels, Install seats last.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
I would also hold off on installing the windshield and rear glass until the headliner rear deck speakers (if used) and deck cover are installed. Just makes life easier especially the headliner install
69 Pro Tour - LS7/T56 Building ![]() C6ZO6 Vette Lemans Blue 69 Z28/RS Tribute 355/5 Speed(SOLD) 69 RS Clone 427/TH400(SOLD) 67 RS ZZ502/5 Speed(SOLD) 69 Camaro 406 SBC/TH400(SOLD) |
JohnZ CRG '69 Z/28 Fathom Green |
#11
From a factory, GM point of view these cars were put together to be forgotten. Don't try too hard for history w/o evidence.VCD
#12
How true. And in some places they forgot to put them together.
One owner 69 Camaro,(yep, bought it new )RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers. TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60' All with 1960's stuff. (except tires and converter) + MT Super Scavenger headers. 1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too. ![]() http://epitomesrebuild.com/ |
#13
I found what I think will give me the info on hardware parts etc... And I am gonna get the Fisher manual as well from what I hear it has alot of exploded veiws of interior parts and door parts window hardware etc... Just food for thought, I am not trying to put it back to date code specs. I got this car without eveything and with no way of knowing or seeing whats missing. And it being my first Camaro just makes it that much more difficult. Thanks Again for all the info
#14
If you find a part and don't know what it is and where it goes, post a picture of it and ask.
#15
Big Rats run at night!<br />niterat@hotmail.com |
| Sponsored Links | |
Advertisement | |
