Engine Stamp - VIN - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Dec 11th, 12, 12:46 PM
OUTarHeel OUTarHeel is offline
Chad
Default Engine Stamp - VIN
I spent some time going over the "decoding" process of my camaro last night...which is just a run of the mill 1969 with a stock 350 in it. The motor does not match as casting number and engine code stamp indicate it is a 350 from 1973 or 1974....that being said, I cant find the engine VIN stamp anywhere?
The engine code is stamped on the front of passenger side header, somewhat hidden by the altenator. After some research it seems that usually the engine code and engine VIN were stamped in the same place, but this isnt the case....any ideas? I have checked down by the oil filer, but sight of it anywhere
Thanks,
Old Dec 11th, 12, 01:11 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
Default Re: Engine Stamp - VIN
What is the information that you can see stamped on the "pad" in front of the passenger side cylinder head?
If it is a 73 or 74 engine as you say and it was installed in a vehicle, then it should have a partial VIN there. You might need to move the alternator to see it and clean the pad off with paint remover.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Dec 11th, 12, 03:06 PM
Chad
The cast # 3970014
Engine Code T0406CKB
I cleaned the pad with degreaser and a scrub brush...no other number listed.
Old Dec 11th, 12, 03:48 PM
bcm66's Avatar
Bryon / Big B
OK, well I guess there must not be one. But that is not normal from what I have seen.
Any way you can check the casting date? It will be hard to see, but it is back on the bellhousing flange area behind the distributor.
That casting number was used through the 70s and that CKB application code was used for the 350 in several years in some cars (Chevelle, Nova, Camaro). Could be 72, 73, 74 or 77.
Old Dec 11th, 12, 04:28 PM
Chad
I'm not sure if I could make out all of the numbers, but I believe I saw:
08 72
Old Dec 11th, 12, 05:30 PM
bcm66's Avatar
Bryon / Big B
It's probably D 8 72. If so, then it was probably originally from a 1972 Chevelle.
It is still a good engine.
