4spd crossmember compatible with th350..? - Team Camaro Tech
Old Dec 25th, 12, 09:28 PM
PairOf69's PairOf69's is offline
Default 4spd crossmember compatible with th350..?
gonna be a sad day but i'm putting a th350 in my original 4spd 69 in order to get the project moving along, but was wondering if I could reuse the 4spd crossmember?
69 X11 Basket Case
C5 wheels/brakes,Hotchkis,ADDCO,MOOG
69 chevelle
Old Dec 25th, 12, 10:10 PM
67Dale 67Dale is offline
Tech Team
Dale
Default Re: 4spd crossmember compatible with th350..?
Crossmember and driveline are the same. Turbo 400 is the one that is different.
67 RS Camaro
71 SS Nova
68 Chevelle
Old Dec 26th, 12, 02:52 AM
buenymayor buenymayor is offline
There are 3 crossmembers for the first gens. One for the BB/TH400, one for the BB 4 speed, and the one for the 6cyl/SB cars, both AT and manual transmsission. If your crossmember has an oval hole for access to the transmission mounting bolts, it is the one used in for all the 6 cylinder/SB cars. What frame stands/engine combination are you using?
Experience...... It's what you get when you didn't get what you wanted.
http://camaro.bertke-one.com/teamcam...%20Camaro.html
Old Dec 26th, 12, 11:26 AM
i'm doing a carbed Ls 6.0, I think I've got the tall narrow frame mounts, car came with a 307 originally.
one more question...would a 2200 or so stall converter be miserable to drive with 3.08 gears? basically trying to get this car moving under it's own power again for the first time in 23yrs, i'll eventually replace the 8.2 with something more stout.
69 X11 Basket Case
69 chevelle
Old Dec 26th, 12, 12:38 PM
TJS69 TJS69 is offline
Tom
Smile Re: 4spd crossmember compatible with th350..?
Just an FYI... the frame mounts are not called tall and narrow. Engine mounts are either "tall and narrow" for '69 302, 350, and 396 or "short and wide" for all 67-68's and 69 307 or 327's.
The frame mounts that use the "tall and narrow" engine mounts are shorter than what the "short and wide" engine mounts use.
You would simply have the 307/327 frame mounts that would use the "short and wide" engine mounts.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Dec 26th, 12, 01:31 PM
appreciate you sorting that out, been awhile time to update the memory bank
69 X11 Basket Case
69 chevelle
