installing repro body mounts? - Team Camaro Tech
Restoration Corner Where originality comes first
Old Dec 26th, 12, 08:32 AM
69Z28-RS 69Z28-RS is offline
Gary
Default installing repro body mounts?
I purchased a reproduction body mount kit (consisting of 6 cushion assemblies and 6 cushions) for my '69 from Ricks, and I'm ready to install them, but am a bit uncertain on the proper installation. All 3 locations of the cushions/assemblies are different, and there are different PN's on the repro parts *(but of course not matching the Assembly manual PNs!). The assembly manual (UPC 1-section D1) shows four (3) cushion assemblies per side (items 8, 9, 13, and 15), although item 15 shows it was a mod/update - although my copy of the AIM is not sufficiently legible to ascertain whether it was added or taken away!). The radiator core support location has a smaller hole, so I think that one is clear, but the rear most location in the AIM shows the two assemblies (and I only have one plus a cushion).. Has anyone worked thru these issues and have a nice simple answer to these questions?
Note: My originals were so deteriorated, I didn't make good enough notes when I disassembled and I want to get this right the first time! Any and all help appreciated!
Gary
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
Old Dec 26th, 12, 09:05 AM
BobKovacs BobKovacs is online now
Bob
Default Re: installing repro body mounts?
My AiM has two mods- the first says "item 15 added", and the second says "item 15 was item 10", so at one point they were showing both mounts being the same. I put Energy Suspension poly mounts in my car, and they had different parts in the 2 locations. The instructions called for a shorter sleeve in the rear location (and a different upper cushion)- do you have two different sleeve lengths? If so, it looks like the shorter sleeve and thinner cushion would go in the rear. The bottom cushions were all the same in my kit.
Old Dec 26th, 12, 09:54 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Gary, I did mine with original type too. But as bad as they were, I did one at a time so that I was replacing the same size ones as I went along. Im not sure if the photos will help but feel free to browse thru them here... frame bushing pics
I hope your caged nuts are in place and not rusted out or spinning when you put the bolts up into them.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Dec 26th, 12, 10:16 AM
DjD's Avatar
DjD DjD is offline
Dennis
I've posted this several times...
Originally Posted by DjD View Post
This is for a '69, I would expect it's the same for '67 but you might want to check the AIM...
Stacked it goes like this;
Core Support .. Center Mount ..... Rear Mount
bolt ............... body (cage nut) .... body - (cage nut)
washer .......... cushion asm ......... cushion asm
cushion ......... sub-frame ............ sub-frame
core support .. cushion ................ cushion
cushion asm .. washer ................. washer
push nut ....... bolt ...................... bolt
frame
washer
lock washer
nut
There are 3 diff cushion asm sizes used and 2 diff cushion sizes used. Be sure you got the right pieces in the right places.
Even if most of the rubber is gone from the old the remains should be able to help you identify what fits where...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Dec 26th, 12, 10:28 AM
Gary
Hi Bob and Jim. Thanks for your responses and the photos. My rubber cushions looked similar to Jims when I removed them, but my metal parts were a bit better (less rusty). - probably attributable to my southern location and the car's being stored in my basement for the past 32 yrs! My bolts are great condition as are the cage nuts.. wasn't even much of a problem removing the bolts. I will reuse the bolts and large washers after cleanup.
My concern was mostly the rear upper and lower 'cushion assemblies' - items 13 and 15 in the AIM. The AIM shows both as assemblies (ie. rubber cushion mounted to a metal sleeve), whereas the replacement parts has only one 'assembly' and one 'cushion'. I think I should use the cushion assembly in the item 13 upper location (between body and frame), and the cushion between the large washer and the frame (item 15 , or lower location). If you think this is wrong, please yell loudly!
Gary
Gary
69Z28-RS
Old Dec 26th, 12, 10:30 AM
Gary
Default !
Dennis: Thanks.. your diagram matches what I've been able to put together and determine, so THANKS for confirming!
Gary
69Z28-RS
Old Dec 26th, 12, 11:31 AM
zdld17 zdld17 is online now
Don
If I recall when I replaced a set of 5 year old OEM rubber mounts that flattened , I used the poly mounts , the 5/8" bolt called for 140# torque. Don't forget the anti_sieze compound.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Dec 26th, 12, 05:09 PM
Gary
The AIM specifies 30-40 ft-lbs on the Rad Spt to frame mounts, and 75-95 ft lbs on the ones under the firewall. the back one is probably similar although not specified in the AIM.
Gary
Gary
69Z28-RS
