brass or stainless steel brake calipers - Team Camaro Tech
Old Dec 27th, 12, 09:28 AM
leespeedshop leespeedshop is offline
lee
Default brass or stainless steel brake calipers
I am interested in getting my 4 piston calipers sleeved in either brass or stainless. Has anyone done this and if so who did you use and what was the cost.
Old Dec 27th, 12, 11:52 AM
Vintage 68's Avatar
Vintage 68 Vintage 68 is online now
John
Default Re: brass or stainless steel brake calipers
While I've had some 4-piston units sleeved locally years ago in $$ - I now prefer Brass ...
I had some issues with a $$ sleeved unit having a sleeve come loose and begin to slide out after a few years of use.
Granted this vehicle saw some track-time and it may have resulted in the caliper(s) getting hotter than they would if 100% street driven (the most likely reason as stated by the supplier when returned for repairs) but still, it was a very frustrating (and expensive) issue to correct that I have never had with a Brass sleeved unit.
I have been using a California vendor for the past several years - but he is retiring the end of the year
He will do your work if you get it to him by Dec. 31st though so better hurry if you choose him.
Link to his site - http://www.brakecylinder.com/index.htm
I have also been given a new vendor with very good reviews to try next year.
I heard they do lots of Corvette work, so maybe JohnZ or others can comment on them
Link to WhitePost - http://www.whitepost.com/brake.html
Hope this helps
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Dec 27th, 12, 12:00 PM
nashcar nashcar is offline
Steve
I've had all mine done in the past with SS with no problems. I just had my master and rear wheel cylinders done for my Z28 by Whitepost and they use brass. They have a lifetime guarantee, we'll see. Not cheap, I think the master was $185 and the wheel cylinders were $85 each.
1969 Z28
http://www.byjanmarie.com/camaro/Z28.html
1969 Firebird 400 one owner.!
http://www.byjanmarie.com/firebird/69.html
My new project for 2010 DONE/ Sold.
http://www.byjanmarie.com/camaro/69camaro.html
2002 Camaro SS LE/SLP
Old Dec 27th, 12, 02:04 PM
Vintage 68's Avatar
John
Wink Re: brass or stainless steel brake calipers
The 'going' rate for most Masters is @$200 with Wheel Cylinders running just under $100 ea.
(of course YYMV - and they will always adjust pricing if the unit is really dirty, rusted or needs rework of fittings/threads ...)
1968 Convertible
Some trucks
Old Dec 28th, 12, 08:56 PM
lee
thanks for all the feedback. I already contacted Whitepost and the calipers work is quite expensive,...but then again you do get a lifetime warranty. For the guys who got theirs done in brass what brake fluid did you use.
Lee
1967 rs/ss
1969 Z28
Old Jan 13th, 13, 07:53 AM
Steve
I had silcone in mine and have used it for years with good results, some will say it's no good. Whitepost says not to use it so I changed to DOT3.
1969 Z28
Old Jan 13th, 13, 08:01 AM
satz28's Avatar
satz28 satz28 is online now
Rob
Why no silicone brake fluid?
Rob
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
Old Jan 13th, 13, 08:03 AM
bilodeaulynn bilodeaulynn is offline
Yeah, what is wrong with silocone?
Lynn
Old Jan 14th, 13, 08:57 AM
Vintage 68's Avatar
John
There is really nothing "wrong" with Silicone (Dot-5 NOT 5.1 ) - if ... the system is specifically designed for it, as are many higher end performance vehicles.
The problems arise when folks start mixing early hydraulic design components with the different fluid characteristics of a Dot-5 system.
Most common 'short-term' issues are due to components sizing leading to "spongy" pedal feel and braking bias calibration(s) which takes time, and familiarity with, to overcome until a good balanced feel can be achieved.
You can select components during system construction to minimize this if your building/rebuilding a vehicle braking system from ground up.
OEM systems using this fluid are specifically engineered from the 'get-go' to work with these characteristics.
Early glycol based (Dot 5.1) fluids were also not fully compatible with many of the elastomers (you know - rubbery stuff ) commonly used in seals and internal o-rings.
The glycol-ethers can/would attack the components over time and leaks were the common indicators of 'issues' ...
The true 'silicone' fluids don't exhibit this, and most components are now multi-fluid compatible from the vendor, so this is not as big an issue as earlier - but still a concern depending on your systems history and composition.
Lastly - silicone fluids are completely 'non-hygroscopic' (can't absorb any water ).
That sounds like a "good-thing" right?
Wellllll .... not so much
It depends on where in the system any entrained moisture (oh it will get in there, trust me ) comes to rest and it's concentration(s).
It will most likely settle to lowest points in the system - think calipers here - and when it does it then is in the worse place it can be, right where the maximum heat zones are in the system. And since water has a very low boiling point you can probably guess what happens to your braking effort as you get into spirited braking cycles and the caliper temps exceed 400+ degrees
[Note: the earlier Glycol based (Dot-5.1) fluids just absorbed some of this moisture - so even though they were hard on seals, they didn't have the lost of effort issue 'true' silicones do.]
On true performance and/or Race systems, the fluid is bleed, checked, serviced and/or changed very often during routine vehicle prep cycles - so these guys don't see much if any problem with moisture entrainment.
Hope this helps understand the 'why' most suppliers don't recommend the "DOT-5" type fluids.
And ... I'm sure you'll most likely never exceed the limits of a good DOT-4 anyway, so there should be no incentive to 'pioneer' use of silicone on the majority of street driven vehicles.
Oh, wait a minute ... I just thought of a GREAT use for Silicone
1968 Convertible
Some trucks
Old Jan 14th, 13, 09:07 AM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Thanks for the explanation John.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Jan 16th, 13, 08:15 PM
Steve
Whitepost says it can affect the seals in the cylinder or caliper.
1969 Z28
