| Team Camaro Tech Current Topic: 1967 Camaro wires cut horn relay | ||
| Electrical & Wiring Troubleshooting electrical. |
I searched through the horn relay problems and couldn't find my problem, While repairing the hideaways three wires were tucked up under the the fender with the relays. blue, white and large red. it looks like they would have attached to the rad support above the horn relay where guess what there is a blue, white and large red wire. The large red wire goes into a "resister" and comes out orange. I saw the picture of the horn relay and the wires that go into mine appear correct but in the shot there is a blue and white in the background. Upon further investigation I have now found a brown wire that was cut under the newer tape you can see in the pic. It is now attached to a red wire running under the rad support to the passenger headlight which was dim after hooking up the hideaways. I am attaching a couple pics for help.[ATTACH][ATTACH]Attachment 31495[/ATTACH][/ATTACH]
| Sponsored Links | ||
Advertisement | ||
you should really get a new headlight harness, they're fairly inexpensive and you're not going to need to worry about the car catching fire.
Let me check my materials and see if I can figure it out for you.
Jason 2010 Camaro 2SS/RS - 1968 Camaro - 2000 Ford Exploder |
I assume in past attempts to repair the hideaways there has been some creative wiring. All I can see is the wires around the relay. Everything else appears normal to my untrained eye.
Are you still running factory charging and external voltage regulator? If you are these would be the standard front harness wires. Blue brown and red with fusible link.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear http://69pace.blogspot.com/ |
I see a horn relay but not a voltage regulator....or is it not in the pic ?
68 Camaro~ LSx RedЯum <-Pics http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here |
Its been over 30 years since I have had my hands on a car I could work on, so lets see how my memory serves me.
There is no voltage regulator now, The brown wire (now spliced to red) runs to the alternator. I believe later alternators had the voltage regulator built in ? If I am right then the car has been rewired for this alternator. The wires that were cut and tucked away are of no further use ? I probably have a bad headlight since it was in and out 5 times. |
Do you have a wiring schematic? I looked in mine, it is possible that those are the wires that go to the voltage regulator. There should be a blue, white and red wire that goes from the regulator to the alternator. Has someone replaced your alternator with an internal regulated alternator?
Brian '67 SS/RS, 350ci, Muncie M20 http://s1355.photobucket.com/albums/q713/b17brian/ |
Yes Brian, that looks like what has happened. I will just tape them up and tuck them away. Mystery solved for today.
Thanks guys I am sure in time you will have me educated !! Rick |
as you found out, it's for your regulator. Going from top to bottom, the wires on the regulator are blue, white, red, brown.
Yeah got it. Dim headlight was broken ground wire for the headlight plug.
Thanks guys for the help. Rick |
#11
Do you have a GEN light with ign switch on, engine off?
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
#12
Yes I do have
#13
And it goes out with engine running?
Charging voltage across battery posts is above 13.8 volts?
#14
Evey thing works as it should. That's why I never noticed anything on the 4 hour drive home when I bought it. It was just when I got into the hideaways that I found the wires. Funny thing though,my son has a friend who is an electrician and he said whoever did the wiring knew what they were doing, everything neat and in the right place.I wasn't there when he looked and never even asked him what he thought. He said no way a backyarder did it.
#15
Rick, your horn relay is upside down. You might think about turning it right side up or the cover could fill up with water.
| Sponsored Links | |
Advertisement | |
