71 Camaro wiper problem - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Thread Tools Display Modes
Old Dec 29th, 12, 08:06 AM
alt66 alt66 is offline
Default 71 Camaro wiper problem
i have a 71 camaro with aftermarket cowl,wipers do not work.understand there is 2 different style motors and i have the non hidden style motor so probably have to switch this out but wanted to know if wiper linkage was different.the current motor hooks up to the linkage but wipers don't work. if i diconnect the linkage the motor runs but has no power i can stop it from turning with a pair of pliers.
Old Dec 29th, 12, 01:44 PM
dzs dzs is offline
darryl
Default Re: 71 camaro wiper problem
make sure it is grounded it grounds to the firewall i had to scrape some paint off to get a good ground
Old Dec 29th, 12, 05:57 PM
thanks i'll double check that
Old Dec 30th, 12, 11:03 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
Default Re: 71 Camaro wiper problem
If I recall the difference in the motors is Depressed park. Not real sure how to explain it, but the standard wipers basically just stop at the bottom of the windshield. The depressed park stop at the bottom and the gear rotates further to retract the wipers under the cowl. I don't know if the linkage is different but I rather doubt it.
Jeff
Old Dec 30th, 12, 02:03 PM
thanks
Old Dec 30th, 12, 02:16 PM
twozs twozs is offline
mike
1
Old Dec 31st, 12, 02:31 PM
72LS3Z27 72LS3Z27 is offline
Chris
Jeff
Yeah,the linkage,motor,and arms are different for standard and hideaway.
The motor is the barrel shaped one for hideaway(regular is square)
The linkage is also different(recognizable visually by three bolts bolting the wiper pegs on,for hideaway,as opposed to two,for standard.)
And the (one?)wiper arm has an additional added sub arm(for hideaway)to it.So,instead of a one piece wiper arm,its two piece.
And lastly,lol,for the early years(70-73),there is an addition mounting plate(hideaway)that goes in between the motor and firewall.
Old Jan 2nd, 13, 07:23 AM
thanks for the info i do have the standard setup on it
Team Camaro Tech > Generation Specific Forums > Second Generation      Current Topic: 71 Camaro wiper problem
Location
Location
First Name
Human Verification
