Quadrajet Cold Start - Team Camaro Tech
Thread Tools Display Modes
Old Dec 31st, 12, 06:38 PM
Myfirst 69SS Myfirst 69SS is offline
Mark
Default Quadrajet Cold Start
Hey guys looking for some advice. I have a 69 Quadrajet with a divorced choke that is running like crap on cold starts. I will do my best to describe the problem. Upon cold starts the car starts and struggle to maintain 600 rpm. The high idle is set for 1200 rpms, when it is struggling the high idle cam is up, choke is closed with the proper 1/4" space being pulled from the choke pull off. also worth mentioning it is running rough as if it has a miss or is starving for fuel. If I keep the car running eventually the idle comes up to the 1200 rpms with no change in the choke or fast idle cam which all appear to be working properly.
Once the car warms up it runs fine and smooth.
Any thoughts or suggestions?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Old Dec 31st, 12, 09:42 PM
Everett#2390's Avatar
<Jake-68's rule
Default Re: Quadrajet Cold Start
Next time of cold start, have assistant start engine and you open choke plate manually to see if it smooths out.
If so, then you may need to bend the choke pull-off rod to open plate, since it reads like choke pull-off is working.
Old Jan 1st, 13, 12:55 AM
puff puff puff puff is offline
May want to read this:
http://www.chevelles.com/techref/Adj...tic_Chokes.htm
Old Jan 1st, 13, 02:08 PM
MRCOOL_RSSS350 MRCOOL_RSSS350 is offline
Nick
I think your carb drains off from the plugs shown in the pic and floods the cylinders' you can re seal them with JB weld or replace them.
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
Old Jan 4th, 13, 07:06 AM
Mark
puff puff-Nice article, thanks. Thought I would update everyone on the issue I seem to have resolved. I put a rebuild kit in the carb. over the summer, car ran fine afterwards. In going over everything trying to find the problems I found the screws holding the carb together were loose, probably from the change in temp. tightened them up along with the carb to intake bolts and bam! Running fine on cold start up. I guess everything shrank when it got cold and loose screws/bolts led to leaks causing the problem.
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Old Jan 4th, 13, 07:14 AM
<Jake-68's rule
Cool! Maybe she just wanted to be touched...
Old Jan 4th, 13, 09:03 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
Maybe
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear.
Finally back on the road after being stranded in the garage for over 20 years. Follow her progress back to the road http://69pace.blogspot.com
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Quadrajet Cold Start
Location
Location
First Name
Human Verification
