Rearend out of a 67/68 Camaro value? - Team Camaro Tech
What's it worth? & ebay discussions
Old Jan 1st, 13, 04:50 PM
stevea stevea is offline
Default Rearend out of a 67/68 Camaro value?
I am looking at buying a parts truck for my 50 pickup. It comes with a 67 or 68 Camaro rearend. I don't need it and was wondering what it would be worth? I don't know the gears or what it came out of other than that. Thanks
Old Jan 1st, 13, 05:02 PM
67Rally's Avatar
67Rally 67Rally is offline
Brent
Default Re: Rearend out of a 67/68 camaro value?
If its got a 10 bolt, it's not worth much.
A 12 bolt will bring some money, and if its a 12 bolt posi it's worth even more. There should be a code on the passenger side of the axle facing forward that will decode what it is. There should also be a code on the pumpkin itself. Post those numbers and we can tell you if it's worth $100 or $1500.
Old Jan 1st, 13, 05:03 PM
cnorton7311 cnorton7311 is offline
Tech Team
Chuck
Count the number of bolts used fasten the cover on the rear of the housing.
Old Jan 1st, 13, 05:04 PM
I did count the bolts and it's a 10 bolt. If I could get $100 I would be happy.
Old Jan 2nd, 13, 12:49 AM
Garfields Maro Garfields Maro is online now
Garth
A 67/8 10 bolt would be an 8.2 " differential. I doubt you can give it away. An 8.5" 10 bolt from a later model is worth a few hundred. There's a pic in the following link showing what the 8.5 looks like, post #8.....http://www.camaros.net/forums/showth...ight=rear+axle
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Jan 2nd, 13, 04:01 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Default Re: Rearend out of a 67/68 Camaro value?
My old 8.2" has been behind the garage for 10 years. I'm too lazy to drag it to the curb.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Jan 2nd, 13, 08:19 AM
BobKovacs BobKovacs is offline
Bob
Mine is sitting in my storage unit, waiting for my next run to the scrap yard....lol. Once i get the headlight buckets and other pieces off the fenders and get the innards out of the doors, they'll be going as well.
Old Jan 2nd, 13, 08:43 AM
BPOS BPOS is offline
Al
A fun project is to get a new blade for the Sawzall and cut it up, then it's only a few light loads out to the curb.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jan 2nd, 13, 09:03 AM
Joe Harrison's Avatar
Joe Harrison Joe Harrison is offline
67 Camaros Rock
Caution.......you may have to pay someone to take it.
If it's a posi you might get something for it but not much.
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn.......
Then, you have enough horsepower."
-Mark Donahue
My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805
Old Jan 2nd, 13, 09:04 AM
HwyStarJoe's Avatar
I have another rear on Craigs List... I might throw it on there as well just for grins.
SEMA ACTION NETWORK
Old Jan 2nd, 13, 10:02 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
The camaro rear will not fit the '50 unless someone has changed the spring perches. If so, then the rear will not be worth the price to put the perches back to spec.
PS, I have a '51 3100 project too
Old Jan 2nd, 13, 11:10 AM
Melrose RS Melrose RS is offline
Tom
All I'd have to do is put a sign on the street in front of my house and the scrappers would beat down my door!
They will grab anything metal I drag to the curb.
Brent's 10 bolt is still sitting behind my garage waiting for a project car to go into.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
(And an 8 year old riding shotgun. )
the Melrose rs - L30 327/275hp
Old Jan 2nd, 13, 01:14 PM
HwyStarJoe's Avatar
Hate hijacking a thread, but... I live on a main artery in our neighborhood so if something even remotely metallic is seen by the curb, it doesn't last 15 minutes, at most. Piranha attack!!
More than once I'll still be walking back up the driveway after putting something out there and someone has already stopped to grab it!
I've helped more than one scrapper load his vehicle.
SEMA ACTION NETWORK
Old Jan 2nd, 13, 01:56 PM
vjp819's Avatar
vjp819 vjp819 is offline
V.J.
the weight of that rear end is probably worth a day or two of collecting bits and pieces of scrap metal.
1968 LeMans Blue Camaro-Resto in progress
Old Jan 2nd, 13, 02:17 PM
Petes L48 Petes L48 is offline
Russ
Why not just bury it in your back yard?
May your past be the sound of your feet upon the ground, carry on - Fun., Some Nights
