427 cam choice - Team Camaro Tech
Old Jan 1st, 13, 06:36 PM
ernies 69 ernies 69 is offline
ernie
Default 427 cam choice
first ill start with my combo i currently have, 427 c.i. 396-375 cam, 215 heads with app 100cc chambers, holley h.p. 750 carb with 68 jets up front and 72s in the back, and a 390 hp intake. im going to pull the trigger on a set of race rite heads part#2061006, and a edelbrock perf air gap intake, roller rockers, advice im needing is the choice of cam, im open to all..... solid,hydraulic roller, flat tappett etc, and what do i jet the carb at for a good starting point, if anyone has a similar combo or can steer me in the right direction i would appreciate it. please dont try and talk me out of the 427, i love it . thanks guys
Old Jan 1st, 13, 08:19 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Default Re: 427 cam choice
I'd call John at Bullet Cams, 662-893-5670. They make cams for Pro Stocks and Pro Streets or for the hobbyist. Bullet will email you an in-depth questionaire and can recommend/grind a cam for your application.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Jan 1st, 13, 08:56 PM
68rs406 68rs406 is offline
Sean
X2 with what Michael said, you won't be disappointed.
I think a cam change alone would help what you currently have, but add heads etc. and that thing will wake right up.
As for the carb, if it runs well right now I would leave it be, it should be close enough to run. If the vacuum etc. falls way off with the new parts it may need more attention, but I'm all for using a known working part and getting it right once it's running.
And I can't imagine why anyone would try to talk you out of a 427... awesome motors.
Sean
1968rs, formerly a 406 sbc, 354" SB2.2 coming soon...
"Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari
Old Jan 2nd, 13, 01:56 PM
ernie
ive used bullitt in the past on a mouse motor, with good success. i was hoping that someone had a build simular to mine to give me a { real world opinion} on what i should try for this combo. also i forgot im running 355 gears and a 4 spd. it will see occasional strip pulls, and but i want it street friendly. thanks for the replys.
Old Jan 5th, 13, 01:32 PM
ernie
moderators, can we move this thread to the engine forum to maybe get more opinions, thanks
Old Jan 10th, 13, 10:57 AM
Fred Ficarra Fred Ficarra is offline
Fred
Also your cam choice is mostly dependent on compression ratio. You don't mention pistons.
Talk you out of a 427???
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Jan 10th, 13, 09:33 PM
ernie
my compression ratio will be 11-1 with 118 cc heads. im looking at comp cams part#11-432-8.
Old Jan 11th, 13, 09:53 AM
.gearhead.'s Avatar
.gearhead. .gearhead. is offline
Jim
Suggest using LSM or Bullet. I've had both in 408, 421, 427, 434 and 436. The LSM cam was spec'd to help in ways I was skeptical about but proved true. Both great. I prefer LSM.
1968 Camaro
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
