| Team Camaro Tech Current Topic: 69 Wiper Motor Diagnostics | ||
| Electrical & Wiring Troubleshooting electrical. |
Guys, would any of you have a step by step wiper motor diagnostic method.
My wiper motor will not park blades when switch is moved to off position. I recall I dealt with this before and corrected it by replacing the wiper motor. Long ago JimM sent me some steps to go thru but , that was long ago and I can't seem to find that sheet. Wonder if anyone has such a method of correction , other than replacing one part at a time. My wiper motor does have the ground strap as well as the wiper switch ground into the headlamp switch plate. Any comments?
Don TC # 349 Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E http://s102.photobucket.com/albums/m...t=115_1577.jpg |
| Sponsored Links | ||
Advertisement | ||
I made up the test bench diagram in the electrical section quite some time ago, it will still be there
Wiper motors get the 12v all the time and the switch actually controls the ground path. So with the switch turned on, the circuit is completed through the switches ground path. But when you turn the switch off, the ground path then moves over to the park circuit. The park circuit is controlled by a tab on an internal gear that keeps the motor grounded through the chassis (the wiper motor case is grounded via the brass ring on 1 of the grommets). When the tab reaches a certain point it opens the case ground, then the motor stops.You need to make sure the case is trully grounded and not gummed up. If the ground is intact, then something when wrong with the internal grounding tab mech. |
Here is what the inside of the wiper motor looks like. Its hard to see in that pic, but the tab is on the green gear in between the teeth and the shaft (around 9 o'clock). The park circuit contacts (2 sprung metal contacts) are to the left of the wound resistor. The tab on the green gear slide between the 2 contacts to break the ground to stop the motor.
![]() Since we do not drive that much in the rain, you can always just turn the wipers off at the correct time
Hold on a bit... brain just got in gear (been sick since xmas
) do the wipers just stop when you put the switch to off? If so, then the park circuit ground is ALREADY broken. Its means the metal contacts are already apart or are not connected to the ground. since your wipers work from the switch, the switch grounding is fine. I would take a wire from the neg battery and go directly to the case of the wiper (alligator clips work well) on an unpainted spot. And try the park again. |
Get Well .
Don I just use Rain-X and forget the wipers
as fast as you drive, water wont sit on your windshield at all
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Photos for viewing Learn How To Post Pics here |
I also recall MarkLW? coming from BC, with no wiper motor in the hole too. Fast car. Come to think of it, I don't recall any door glasses. Rained on me all way from Billings to Dalhart, only used wipers to find gas stations .
My windshield on my camaro or Tahoe never squeeked at all with both wipers and RainX , Maybe its the NJ smog?
#12
Must be because I've used RainX for years.
*---------------------------------* STREET MACHINES OF ROCHESTER SEMA ACTION NETWORK UNITED SERVICES ORGANIZATION (USO) |
#13
Wouldn't doubt it
#14
Although, I drove through NJ quite a bit this past 6 months, a lot of it in the rain, and they still didn't squeak. Maybe you just need new blades Kevin!
#15
And you did not stop by and say hi?!?! sheesh
| Sponsored Links | |
Advertisement | |
