Header diameter Question - Team Camaro Tech
Old Jan 5th, 13, 04:33 PM
fast69camaross fast69camaross is offline
Default Header diameter Question
1973 camaro is my project.
I have a fresh sbc 350 10.1 motor.
Hydraulic roller tappet cam
Basic Operating RPM Range
2,400-6,000
Intake Duration at 050 inch Lift
234
Exhaust Duration at 050 inch Lift
242
234 int./242 exh.
Advertised Intake Duration
294
Advertised Exhaust Duration
302
Advertised Duration
294 int./302 exh.
Intake Valve Lift with Factory Rocker Arm Ratio
0.533 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio
0.548 in.
0.533 int./0.548 exh.
Lobe Separation (degrees)
112
Ported World products sportsman heads
weiand stealth instake
Quick fuel 750 carb
I was thinking about the 2117 1/34 hooker super comp headers.
Do they fit with air conditioning?
Old Jan 5th, 13, 08:55 PM
Straight-line-69 Straight-line-69 is offline
Default Re: Header diameter Question
You' be ok with 1-3/4" tubes but most would recommend 1-5/8" headers for a 350 that never sees the dark side of 6000 RPM.
Old Jan 6th, 13, 05:29 AM
Everett#2390's Avatar
<Jake 68's Rule
Hooker 2130 would be a better choice, 1.62" OD X 30" long.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Jan 6th, 13, 08:53 AM
Luwi67 Luwi67 is offline
Bobby
What is the size of your exhaust ports, doesn't make sense to go much bigger than that or the velocity will suffer in more ways than one.
67 Camaro 350
M20 4spd console,
8.5 30 spline Eaton posi,
Moser shafts, Richmond 3.73
custom Spintech exhaust
black/black
Old Jan 6th, 13, 02:42 PM
ok.What size exhaust would you recommend?
Old Jan 6th, 13, 03:00 PM
zdld17 zdld17 is offline
Don
Nothing larger than 2.5" pipes . Its an over kill going larger.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Jan 6th, 13, 07:46 PM
My engine builder said keep the 1 3/4 headers and go 2 1/2 on the exhaust.Will these fit with the air conditioning?
