Mono leaf to multi leaf swap 67 camaro - Team Camaro Tech
Old Jan 6th, 13, 06:15 AM
meusebi meusebi is offline
Default Mono leaf to multi leaf swap 67 camaro
I was thinking of swap 10 bolt monoleaf in my 67 for a 12 bolt with multi-leaf. I know that the 67 does not have stagered shocks as the 68-69 do. So my question is what plates ( that mount to axle and shock absorber ) will I need ? Can I use the ones off my 10 bolt ? Do I need to change shock absorbers since I have read that the ones for multileaf are inch shorter or longer I cannot remember? Last question is the 3 leaf better than the 5 leaf ?
Old Jan 6th, 13, 08:46 AM
Luwi67 Luwi67 is offline
Bobby
Default Re: Mono leaf to multi leaf swap 67 camaro
I think the mono plates for 67 have the shock a bit lower and with the 5-leaf the shock could top out before the suspension. You could use plates from a 74 Nova, I'm pretty sure the shock mount isn't as low but, look into that first. They are also non staggered for multi.
I'd go with the 3-leaf and ditch the rubber pads for a 1/4" steel spacer plate to take up the remaining space between the axle perch and shock plate. If you go with a Caltracs set up, you wont need lower plates because they come with them and have a relatively high shock mount so you can keep the same shocks.
Either way, with the 3-leaf you should be able to keep the same shocks without any shock extender.
I'll try to confirm what I said about the Nova plates later on today.
67 Camaro 350
M20 4spd console,
8.5 30 spline Eaton posi,
Moser shafts, Richmond 3.73
custom Spintech exhaust
black/black
Old Jan 6th, 13, 08:48 AM
TJS69 TJS69 is offline
Tom
Smile Re: Mono leaf to multi leaf swap 67 camaro
I am no expert, but here are a few thoughts.
You will want slide-a-links or traction bars because of non staggered shocks. These will have their own shock plates.
3 - leaf or 5 leaf ? That will be your personal choice with what you plan to do with your car. There are also 4 leafs out there. (stock on z28's)
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Jan 6th, 13, 09:07 AM
Thank you that answers all my questions.
Old Jan 6th, 13, 06:49 PM
Bobby
67 Camaro mono plate on left. 74 Nova multi plate on right. They are both for non-staggered shocks but, you can see the Camaro plate will mount the shock about 1 maybe 1.5" lower.
67 Camaro 350
M20 4spd console,
black/black
Old Jan 6th, 13, 07:05 PM
Steiner Steiner is online now
Steiner
Kevin might still have his DSE set. They are for a '67 setup and your existing shocks should work with them if you buy a set of the multileaf shock studs.
http://www.camaros.net/forums/showthread.php?t=213655
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
