Replacement Ducts - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Jan 7th, 13, 06:46 AM
DDZ28 DDZ28 is offline
Dan
Default Replacement Ducts
Does anyone know where to find replacement duct pieces for a non-a/c 69 Z28 w/center console?
69 LeMans Blue X77 Z28 (under full resto)
68 Corvette Bronze RS Z28
68 LeMans Blue SS 396 L78 (9,977 original miles)
Old Jan 7th, 13, 06:50 AM
BobKovacs BobKovacs is offline
Bob
Default Re: Replacement Ducts
Are you looking for the flexible hose pieces, or the plastic ducts (like the defroster duct, etc)?
Old Jan 7th, 13, 06:58 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
The only "ducts" in a 69 non-ac car, is the defrost, pass and drivers fresh air in the upper dash and the floor heat duct that screws to the heater box.the floor heat comes in two styles, with console and without. I think all of those are only available used.
Old Jan 7th, 13, 08:19 AM
Bob
The defrost and floor heat pieces are available new from a few vendors (Camaro Central being one), but they're not cheap- I think the defroster duct is over $100, and the floor duct is something like $85.
Old Jan 7th, 13, 02:48 PM
Dan
Bob, I am looking for the plastic pieces.
Old Jan 7th, 13, 03:58 PM
KevinW's Avatar
Kevin
They are ALL plastic and have various parts. Can you be more specfic on the ducting locations that you are looking for?
Old Jan 7th, 13, 08:23 PM
Dan
Looking for the left air duct w/shutter. I can find the defrost duct aftermarket but not the left or right Astro vent duct.
Old Jan 7th, 13, 09:19 PM
ZLP955 ZLP955 is offline
Tim
Try www.thepartguy.com
if he doesn't have it, he can probably get it for you.
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA; Now a work in progress.....
Old Jan 7th, 13, 09:34 PM
Dan
Tried them, no luck. Sent an email.
Thank
Old Jan 8th, 13, 04:00 AM
KevinW's Avatar
Kevin
If you have them, but they are cracked, they can be fixed.
Old Jan 8th, 13, 06:38 AM
Dan
I have one but it has big pieces missing at the rod location. Found one last night on Camaro Central, not cheap! On to the next adventure.
Thanks all,
Old Jan 16th, 13, 05:00 AM
Dan
Well, I thought I had found one but the seller called me and said it was in bad shape and refunded my money. Still looking.
If there is a repair process someone please let me know. There is about a 1 1/2" piece missing on one side at the shutter shaft location.
Last edited by DDZ28; Jan 16th, 13 at 05:02 AM. Reason: Added word to read correctly
Old Jan 16th, 13, 05:15 AM
bilodeaulynn bilodeaulynn is offline
I had one that was broken. I used a low heat soldering gun with a flat tip or a spade tip, and plastic welded it back together. I used to use that set up to repair the bottoms of skis many years ago.
If you have large missing parts, it is more of a challenge, especially if the large part is missing and it was a molded part. For small missing parts you can use a plastic antifreeze jug. Just cut out pieces to patch. I think the O'Reilly's brand even comes in a black jug.
Plastic welding is very easy with a low heat soldering iron. Pracitce on the jug first.
Don't use a big iron on the hotter setting.
Lynn
Old Jan 16th, 13, 06:06 AM
KevinW's Avatar
Kevin
This guy has the 69 drivers side duct, it was just not labeled correctly.
http://www.camaros.net/forums/showthread.php?t=215207
