| Team Camaro Tech Current Topic: Caltracs with 1 inch lowering blocks | ||
I've done some searching for 67 Camaros running Caltracs with lowering blocks installed and haven't found a definitive answer to my question. A couple of years back I changed out the mono leafs (with slapper bars) to Hotchkiss 1.5 drop leafs and no slapper bars and didn't have any issues with wheel hop. This last year I switched out the 14 inch rally wheels to some Vintage wheel V45's 16 inch wheels and some Falken 255/50 tires(same overall diameter as the BFG radials that were on the 14 inch rims). To achieve the ride height I was looking for, I added a solid 1 inch lowering block and since then, I get occasional wheel hop. I'm assuming I'm getting the axle wrap from adding the lowering block or possibly the rubber compound on my tires? My question is do any of you run a similar set -up (Caltracs with lowering blocks) without wheel hop? I just would like to know how good my chances are of eliminating the wheel hop before shelling out the money.
| Sponsored Links | ||
Advertisement | ||
Caltracs with 1.5" lowering blocks. No wheel hop whatsoever. Make sure you use cast iron blocks.
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Total Seal rings, hand ported AFR 210 heads, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .660" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 8" converter |
I run Caltracs with a 1" lowering block, no wheel hop whatsoever. They will eliminate your wheel hop.
67 Camaro 350 M20 4spd console, 8.5 30 spline Eaton posi, Moser shafts, Richmond 3.73 custom Spintech exhaust black/black |
ran same setup on my 64 with mono leaf. would pull front tires and no wheel hop....
CURRENT PROJECT: 1969 X66 RALLY GREEN/BLACK COMFORT WEAVE, OWNER INSTALLED RS PACKAGE![]() 1987 BUICK GRAND NATIONAL SOLD 2002 C5 coupe Electron Blue 1 owner FOR SALE FUNDING THE X66 BUILD
Thanks guys, that's what I was hoping for. With the new TKO almost broken in, I can't afford to have any type of wheel hop when I'm finally ready to stomp on it 100%.
You can buy springs from Calvert Racing (Caltrac) that are already lowered if you want. I went that route, but not drive time on that car yet. I wouldn't be afraid to use a block.
Royce (NO XQSSS) Bradley www.facebook.com/driveyourjunk http://www.youtube.com/watch?v=DSLsGgDjFXE (brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers) |
May i ask, what size tire and wheel are you running on that car (rr)? it looks real nice/ mean. Loking for inspiration for my new purchase... Lead.
LEADFOOT1 'Still a 1969 Camaro, but now a 1 owner 63 000 miles stored since 82 Convertible! Complete C6-Z06 Brake set-up, DSE Frame conn,19x8.5" and 20x13" Gunmetal-FORGELINE ZX3p's w/345-25-20's P-Zero in full tubs. AirBar Suspended! |
Thanks!
i run hotchkis lowering springs and caltracs, zero wheelhop, although ground clearance with their 2 hole version is pretty bad.
I am so happy with my caltracs and Calvert split leaf mono springs. When I talked to Calvert racing they said if the height is wrong you get one free trade in to send back the rear half of the spring to adjust the height. I went from crazy stock mono wheel hop to none at all.
Sent from my iPhone |
#11
Thanks for the info, i just dont think i can come to cutting up this virgin of a car but i can still keep the stock stuff next to it and drop in myYSI'd Big block and go play for awhile. Lead.
| Sponsored Links | |
Advertisement | |
