| Team Camaro Tech Current Topic: Trying to figure out what 67 I have | ||
| Tag Team De-coding tags and numbers. |
I have checked the CRG site and found the following:
1 = Chevrolet 2 = Camaro 4 = 8-cylinder engine 37 = coupe body 7 = 1967 model year N = Norwood, OH assembly plant 167563 = vehicle serial number sequence Decode for body number: 067177 01A = Built the First week of January. 67-12437 = Standard Interior Coupe. NOR = Built in Norwood Ohio. 717 = Standard Blue Bucket Seats. Z = (A50) Strato Bucket Seats (without headrests). F-F = Car Color is Marina Blue Options: 1E = (A01) Tinted All Glass 2E = (C60) Air Conditioner 3K = (Z21) Deluxe exterior trim And I checked the engine codes which are V0301TMM and t42512819 It appears the engine was built in March in flint. BUT I read somewhere that the engine should not predate the car build? So is this not the original engine? I also found two tags in the glove box in a plastic cover J.P Stevens & Co 7657059 1170-T DK Blue 1967 "F" Body Rear 2 DR. B/S S/12437637 12/12/66 Thanks |
| Sponsored Links | ||
Advertisement | ||
Jerry if your VIN is N167563 then that also should be on the engine not the
t42512819 you posted. Im not sure of the T and which plant that is but the numbers after the "T" belong to another car for sure.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Photos for viewing Learn How To Post Pics here |
I believe that the "TMM" suffix is for the truck series. One source indicates it could be a 1974 or 1980 350ci truck engine. Do you have the block casting number and date?
Jerry G. Z28-1968-07C-Norwood Ermine White, Red Std. Interior 2 Owner, 38,000 miles |
The engine is in the car so I cant find any other numbers only those from the head. Great, so I have a 67 camaro with a 74 or 80 350 truck engine? That seems weird because one thing I noted was that mine has the goofy cable lock system so the engine wont move, it would be odd if someone replaced the engine and then added back that cable wouldnt it? Is there anywhere else I can check that I could see with out pulling the motor.
Jerry - The recall on the engine mount was in 1971 and if the car had the cable on it when the shop that worked on the car replaced the engine they would have more than likely left it alone. As well the previous owner may have left it installed because the car went through the recall back in the day and he felt it was correct for the car...
If your engine was original to the car it will have a hole back by the distributor with some type of plumbing/breather and you might even still have a bolt on oil filter instead of the spin on style.
And yes N167563 is a partial VIN, so I got screwed! Yeah me. Not really screwed I guess but I was told it was a "numbers matching car", I'll bet the 2 speed isnt from a 1970's or 80 truck!
So now what, should I rebuild this thing or chunk it? I really wanted to rebuild the 327. Urghh |
Well look at it this way. Now you have a chance to build anything you want and you can always disguise it as a 327. Both my cars have a truck engine block.
Robert '69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis '67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt '77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25 TC member #18 |
Jerry.....your engine also has a HEI distributor and that distributor did not come on a GM vehicle till sometime around 1975. Looks like prior owner swapped out the entire truck engine into your Camaro.
#11
That engine has the long pad, so it's from a 1974 truck.
Ed
Ed Bertrand 1968 RS/SS L-89 396/375 Convertible My Home Page My contact info Camaro Research Group |
#12
So any sugggestions? Is this motor worth rebuilding, heads, pistons, cam, ect or just trash it? Also I must assume it is possible that they did marry the 350 truck motor with the 2 speed? I have the stock shifter and it feels like a two speed.
#13
Also what is a "long pad"?
#14
Long pad is the part of the head where you see your numbers stamped. Later engines had a 'longer pad' where the numbers were stamped. Older engines in the 60's has a 'shorter pad' that was polished for the stamping guys to hit.
#15
It's a 70's truck block so there's a very good possibility that it's a 4 bolt main. If so, then yes, it's very much worth rebuilding.
Ed
| Sponsored Links | |
Advertisement | |
