| Team Camaro Tech Current Topic: Another Oil Comparison | ||
| Engine General Engine Discussion. |
| View Poll Results: Which oil do you use in your Camaro | |||
| 5W30 |
8 | 10.00% |
| 10W30 |
29 | 36.25% |
| 10W40 |
25 | 31.25% |
| 20W50 |
11 | 13.75% |
| Other |
7 | 8.75% |
| Voters: 80. You may not vote on this poll | |||
With all the information floating around about oil, what is best, what viscosity etc, etc, I thought a poll would be a good idea to see what most guys are using ?? 5w30, 10w30, 10w40, 20w50 etc...
396 X66 LeMans Blue, M20, 373 ... |
| Sponsored Links | ||
Advertisement | ||
Picked 5-30.Its a new crate motor and gm recommends it for it.
So,off the shelf 5-30 for me,with the zinc additve added in.
Moser 12 Bolt w/3:42s Autogear M-22W Gen VI 454 |
Thanks Chris. Just an FYI here. It is reported that adding anything to the oil reduces the protection ability. Again, this is one of those topics where you ask 10 guys and you will get 10 different answers. From what I read, its a NO, NO.
It's not about what most guys are using, it's about the engine and what it requires due to assembly tolerances and components selection... If in doubt what to use, check with your engine builder or the manufacture if it's a crate engine...
But I will stop adding the zinc when the oil manufacturers are allowed to put it back in.
Dennis understood, but do you really know what tolerances you have and what componets are in your engine? Not everyone does. What if you do not have an engine builder or a crate engine ?? A crate engine is one thing, an engine builder is another. I bet if you ask several engine builders this question, you will get several different answers LOL. Most of our engines are pretty much the same, most. (musclecar era)
On top of that there are hyd and solid cams, hyd roller and solid roller cams as well and what you use may depend on how much zinc is in the oil... If you don't know what's inside your engine then start with a 10w30 and check your oil pressure, next use a 10w40 especially watch cold pressure as the rpms come up... I'm not trying to sound like a know it all or shoot down the survey but if you get 50 replies and 50% run 5w30 because they have ls1 or other modern engines and you have a 100k mile 350 built in 1980 with stock GM parts and an aftermarket non-roller cam you are not going to like the results if you fill your crank case with 5w30 because of the survey results...
Pretty much agree with Dennis.
Simple answer is to let your oil pressure gauge tell you what the engine wants. This applies even if you have no idea what the tolerances started off as. The general rule of thumb has been 10psi of oil pressure per 1000RPM. When you throw oil pumps differences in there two engines with the same clearances could have very different oil pressures with the same oil. Still nothing wrong with the poll, It's only a matter of time before five forty shows up, just watch, I think he searches the sites for anything oil related. I also suspect someone is fishing for him.
Royce (NO XQSSS) Bradley www.facebook.com/driveyourjunk http://www.youtube.com/watch?v=DSLsGgDjFXE (brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers) |
I absolutely agree Dennis. I was just hoping for a simple survey comprised of average guys with the typical 327, 350, 396 or even the 454 engine. I know there could be many variables here, none the less I was just curious what the numbers would show. Thanks.
10w40 Rotella in my 400. Tractor Supply had Shell Rotella on the shelf from when they opened the local store. 2001 date on the yellowed bottles. Bought all they had a few years ago.Have 6 bottles left.
67 Plum Mist Met. 408 TH350 3.08 posi http://www.youtube.com/watch?v=FtZfepG5-m8 http://s703.photobucket.com/albums/w...t=MVI_0678.mp4 firstgens.com Camaro Board |
#11
Nice
#12
On the new hydraulic roller cam 400 built a few years ago, 10W-40 Summit Racing conventional for the first two changes. Oil analyses came back beautiful.
Now on 10W-40 Summit Racing semi-synthetic and about ready to send some of it off for analysis. On the solid lifter 327 that came in the other car, initially went with 10W-40 Summit Racing but found out the previous owner's helicoil job on the oil pan didn't work too good so it wouldn't stop leaking. Drained it and was going to reuse it after putting a new oil pan on but flakes of ceramic fell off the crappy headers on it into the drain pan. Went with Shell Rotella T6 5W-40 full synthetic and a half bottle of ZDDPlus. Sent a virgin sample of the T6 off and it was already at 1250ppm zinc. Will most likely go to the T6 5W-40 with no additives in the 400 soon.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
#13
I would love to know the analysis of the 10W40 Summit semi-synthetic. Is this the oil made by Spectro?? Thanks
#14
Yeah, that' it. I reckon they stopped having it made for them last year. Gotta check mileage but pretty sure it'll be ready to come out this weekend and Blackstone usually has the anaysis done within a week of it being mailed out.
#15
Great, I have about 6 quarts left. Thanks
| Sponsored Links | |
Advertisement | |
