| Team Camaro Tech Current Topic: Big Block Dipstick Info needed. | ||
| Engine General Engine Discussion. |
Hey all, new user here. Great site as I can say I have viewed for a few years now. Now I can participate as I just brought home a '69 Camaro vert with a 396. When I got it home and off the trailer I noticed the oil was about an 1.5" above the full mark on the dipstick. I called the guy and he said his guys always used 6 quarts of oil. It's an aftermarket dipstick (chrome). So now I'm freakin on what the dipstick measurements should be and even better but what oil to use. I've read several other posts that seems the majority uses 10w40. Non roller motor (has the lower height valve covers) with a stock pan. Also wanted to verify what year, etc. the engine is. Is there a way to do that without pulling the engine? I think it's located on a pad on the back side of engine, drivers side? I'm assuming the engine is close to year correct as it has a winters intake (snowflake) which I think means rectangle port heads. The guy I got it from was pretty hands off so NOT a good turnover on the car.
Thanks all for such a great site. Really enjoy all your previous posts. Brad in Carmel, IN |
| Sponsored Links | ||
Advertisement | ||
Check the pad on the block located behind the alternator (pass side), oil .... 6 quarts. Unless the oil pan was changed, 5 quarts is the norm. Here is a link: http://camaros.org/drivetrain.shtml#PadStamps
396 X66 LeMans Blue, M20, 373 ... |
Info was just a search away
![]() http://www.camaros.net/forums/showthread.php?t=215518 Welcome to Team CAMARO Brad
1968 Convertible Some trucks ![]() Other V8 things - some of which float Other V6 things - none of which float ![]() Oh yeah, and 1 "Straight-Six" ... ![]() If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Welcome, Brad.
Warning, you're probably going to get gigged from other members for pictures, then you will get an answer.....J/K. Aftermarket dipstick - always needs calibrating, drain oil, and pour in the required volume, then check dipstick. If off, then remark dipstick. Pass side deck under alternator, should be the engine code. Post here and it will be decoded, meaning, HP, date built, and where built. Drvr side side top of bellhousing is the casting number of the block. This would tell the availabilty of the future of the block. Winters snowflake on the intake does not necessarily mean rect port heads. Removing the rocker covers and getting the casting number and date code, will tell the original intent of the heads and build date.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
Thanks guys! I will certainly go check right now and report back ASAP! Still a bit confused on the oil capacity. Is that 5 quarts + 1 for oil filter = 6, or 5 total? Any general info on weight? Just too much info out there on if oil has zinc, etc. as supposedly oil isn'y made the same today for newer cars.
Allright Everett, don't gig me for a dirty car! I just brought it home. : ) |
Welcome Brad. Pics so far look good.
If you did not follow the link that John posted...here is the information. Quote:
And as stated, the stamped information on the front pad of the block, in front of the passenger side cylinder head will help determine what the engine is. See this link.. http://www.camaros.org/drivetrain.shtml#PadStamps The casting number and date from the back would be helpful too. Sometimes the casting date is on the passenger side of the block near the engine mount area.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street. Looking for 68 Camaro with body number NOR 181016 CRG - www.camaros.org |
As far as oil - would need to know more about engine, cam, driving conditions and other info before we could accurately answer. But as a general rule - if the engine is built to 'stock' spec.s and has a 'flat' tappet cam, then a 10w40 oil with a can of EOS (or a higher ZDDP spec.) would be the normal recommendation ...
Thanks guys. The engine stamp by the alt is T08IIIV followed by the VIN: 18S146374. On the back of engine reads (can only determine 6 of possible 7 #'s) 39_6323. The only thing that makes sense would be 3916323. The first digit, and last three digits are clean. Just not 100% sure on the rest. Had to break out the krud cutter! The intake has #3885069. Well,hopefully this isn't a truck engine?
Brian Carmel, IN GO NAVY! ![]() '69 Camaro SS Convertible 396 12 bolt 373 http://www.flickr.com/photos/92269236@N05/ |
396/325 hp engine used with TH400 transmission, originally installed in 1968 full size Chevy (probably Impala) assembled at the St. Louis Missouri plant.
Do you have a pic of the stamps? I will let Warren know and he can add it to the Impala database.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street. Looking for 68 Camaro with body number NOR 181016 CRG - www.camaros.org Last edited by bcm66; Jan 16th, 13 at 01:57 PM. |
#11
http://www.flickr.com/photos/9226923...in/photostream
#12
It's actually a 3-step ![]() (count stamp transitions from the front seal) I'd still do the oil change, add 4-quarts and then check the dip-stick mark (prior to starting the engine. If it's anywhere near the 'Full' mark then it's the right stick and is a 4-quart pan - if not then you got some figurin' to do ... can you get it to 'full' by adding another quart, or , is the stick to short ... You could also just order a 'repopped' dip-stick (NPD #C-1516-4 @$20) for your engine and see what kind of reading you get doing the above check - that should help you rule out the stick ...
#13
#14
![]() But ... the application Suffix (the series of numbers that start with the "T") gives the 'state-of-tune' that GM originally assembled that particular engine to back in 1968. The "IV" denotes the state-of-tune (or HP) as being an RPO-L35 325HP 396CI with a TH400 trans used in an Impala/Full Size The '8' in the Partial VIN (the 18S146874) sequence denotes it was a 1968 model engine application. The 'S' in that Partial denotes it was assembled in St. Louis final assembly plant assigned sequence #146874.
#15
That makes sense. Thanks John. Would the length of the dipstick housing make a difference? It's probably an aftermarket one considering it's chrome.
You guys are great. Hopefully one day I can return the favor for someone on here.
| Sponsored Links | |
Advertisement | |
