Cast Iron Headers - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Jan 16th, 13, 04:11 PM
jeff's69 jeff's69 is offline
Jeff
Default Cast Iron Headers
Hey Guys! Anyone know if there's a good middle ground option between stock exhaust manifolds and tubular headers?
I'm looking at the Sanderson QP1000's. Anyone have any good or bad experiences with them? They've been mentioned in posts from a few years back, but I couldn't find anything recent.
This is for my 69 with a 290hp... nothing too crazy.
Thanks!
Jeff
'69 SS 350 conv
http://i17.photobucket.com/albums/b5...Camaro-web.jpg
Old Jan 16th, 13, 04:24 PM
DjD's Avatar
DjD DjD is offline
Dennis
Default Re: Cast Iron Headers
Sanderson are rather expensive seems to be the talk I have heard... If you don't want full length headers several companys make nice 3/4 length and shorty headers at reasonable prices. I run 1 5/8" tube 3/4 length Dougs on my small block ragtop.
...Dennis
www.camaroslimited.com
Old Jan 16th, 13, 04:52 PM
Jeff
Thanks for the response... Seeing as I don't have too much experience with the differences, what's the benefit of shorty headers over full length?
Jeff
'69 SS 350 conv
Old Jan 16th, 13, 05:15 PM
BobKovacs BobKovacs is offline
Bob
The biggest advantage to shorties is that you don't have all the header tubes and collectors hanging below the body, so you can usually get the exhaust tucked up tighter. That helps avoid the dreaded "speed bump scrape" that becomes more of an issue as we lower these cars to improve handling.
Old Jan 16th, 13, 05:36 PM
Vintage 68's Avatar
John
Wink Re: Cast Iron Headers
The collector exit flange/connection is also nominally larger than any stock or cast manifold so you can spec. larger dia exhaust pipes from the 'shorties' back ...
The only negative I've heard of with cast Sandersons is the latent heat from their large mass causing plug wire issues - that, and a few stories of cracking around the exhaust exit flanges over time ...
Lots of $$$ for a system that can be improved upon.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Cast Iron Headers
Location
Location
First Name
Human Verification
