sbc dart block - Team Camaro Tech
Thread Tools Display Modes
Old Jan 16th, 13, 09:14 PM
80 prostreet 80 prostreet is offline
steve
Default sbc dart block
anyone know if the head bolts go in the water jackets on the shp blocks.
Old Jan 16th, 13, 09:32 PM
Steiner Steiner is online now
Steiner
Default Re: sbc dart block
No, they're blind.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Jan 17th, 13, 03:44 AM
DOUG G DOUG G is offline
Fairly certain they're blind
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Old Jan 17th, 13, 10:50 AM
steve
thanks didnt know what i needed to put on the studs before i put heads on....
Old Jan 17th, 13, 02:06 PM
Steiner
Don't need anything on them. Dart also says to just put the studs in finger tight so they don't bottom out and then let the nuts do the work from the top.
'69 Camaro
500hp/538lbft
www.cmengines.com
Old Jan 17th, 13, 04:34 PM
steve
thanks,but do i need to put their moly or something between the washer and nut....
Old Jan 17th, 13, 04:44 PM
Vintage 68's Avatar
John
Wink Re: sbc dart block
I don't use their 'moly', I just soak the washers and nuts in a small container with light oil (or Tri-Flow if I have enough).
The idea is to slightly lube the contact points of these so there is consistent friction response from the nut during torque procedures.
I actually feel moly (besides being messy) is too slippery to get a cosistent torque reading, at least in my experience ...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jan 17th, 13, 04:51 PM
camaroman7d camaroman7d is offline
Royce
Yes, you need to use some sort of lube. I have used oil and moly. If you check with ARP they suggest their moly.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
(brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers)
Old Jan 17th, 13, 05:05 PM
steve
thanks im hoping i get the heads in tomorrow so i can get this in the car this weekend....
Old Jan 19th, 13, 12:02 AM
Royce
Oh one other thing, the ARP directions will give you 2 different torque specs, one for oil and one for moly. With the one for oil being higher to overcome the friction.
  #11
Old Jan 19th, 13, 04:08 PM
steve
im not sure if its moly i have but its arp assy lube
  #12
Old Jan 19th, 13, 04:09 PM
steve
ill be putting it together monday my heads didnt come in friday because of the snow
  #13
Old Jan 20th, 13, 11:54 PM
Royce
Is it in the white can, with a brush in the lid? Is is a dark grey color? If so, I am pretty sure it is there assembly/moly lube.
  #14
Old Jan 21st, 13, 06:41 PM
steve
its assy lube....
  #15
Old Jan 21st, 13, 07:09 PM
Royce
its assy lube....
You are correct, it is "fastener" assembly lube. It's not moly. I assumed it was moly due to the color, but it isn't. I have used this ARP lube before, several times with no issues.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: sbc dart block
Location
Location
First Name
Human Verification
