Wire from tranny to dash... - Team Camaro Tech
Old Jan 16th, 13, 09:35 PM
67Carl 67Carl is offline
Carl
Default Wire from tranny to dash...
Planning all the steps for my gauge install, thinking it through before I start. I'm going to replace the mechanical speedo with an electric one. Out with the cable, in with the wires. Question: how/where do I run the wires from the trans to the dash? Shouldn't they be covered or protected in some way? Below is the sender that attaches to the trans... Thanks!
Click image for larger version
1967 350, Hurst TKO 600 5 speed, 12 bolt 3:55 posi, RS added
http://photobucket.com/1967_Camaro_Carl
Gone but Not Forgotten: 1970, born with a 6cyl, 350sbc transplanted in
http://photobucket.com/Carls1970Camaro
Old Jan 17th, 13, 01:21 AM
Steiner Steiner is online now
Steiner
Default Re: Wire from tranny to dash...
This only applies if it's your TKO you're doing this with.....
If this is for your TKO it should already have the provision for hooking up the electric speedo and all you need is the plug. The trans already has a sending unit installed in it. There is a small 90 degree black plug on the side of the tailshaft. You use a GM coolant temperature sender pigtail like this for it:
http://www.summitracing.com/parts/pco-5615pt
Ground one wire and run the other wire to the speedo. With an Autometer and most other gauges you just ground one wire and run the other to the speedometer gauge input. It doesn't matter which one gets grounded. You can just protect the wire with a long piece of that corrugated wire wrap or something. Then calibrate speedo as required.
You will also need to plug the old mechanical output hole with something like this:
http://www.summitracing.com/parts/sd...7072/overview/
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Jan 17th, 13, 08:04 AM
BPOS BPOS is offline
Al
For my lockup and trans & temp gauge wires I ran them forward in the tunnel, up the firewall a bit. I drilled a hole in the firewall and installed a grommet.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jan 17th, 13, 08:41 AM
madmax87's Avatar
madmax87 madmax87 is offline
I have the same sender in my 69. I drilled a hole in the tranny tunnel almost straight up from the sender and put a grommet in the hole. I did run the wires in the plastic conduit you can get at any local auto store. I then ran the wires through the console up to the dash. Guess this would only work if you have a console. I would still recommend running the wires in the conduit.
Dennis
69 Z/28. 302DZ, Autogear M22, Red w/black stripes.
69 Camaro, ZZ4, TH350. 8.5 3:42 posi, X11
87 IROC
Old Jan 17th, 13, 08:42 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
I also run my wires on the bottom of the floorboard then to the lower part of the firewall.
I like this type wire protectors or heat shrink tubing.
http://www.mcmaster.com/#standard-ca...eeving/=l2qyy8
http://www.mcmaster.com/#standard-ca...eeving/=l2r0hq
Here are the line clamps I use.
http://www.summitracing.com/parts/sum-g1881
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Jan 17th, 13, 10:54 AM
Carl
Thanks everyone - this is the stuff I'd like to learn before I start the project. The pigtail and plug has been ordered and the mech sender is on the way back. I've got plenty of convoluted tubing and heat shrink tubing so I'll use that. Initially I thought maybe up through the hole with the shift lever but not sure how feasible that is, so I'll use one of the other suggested routes (I do have a console).
Old Jan 17th, 13, 01:12 PM
Steiner
My wideband guage wire is routed up through the shifter and the boot/ring holds it fine.
538 lb-ft - 500 hp
www.cmengines.com
Old Jan 17th, 13, 01:23 PM
Mike
Since you have a console I would drill a hole thru the trans tunnel. Install a rubber grommet and run the wires inside the car.
Install heat shrink on the wires under the car.
Mike
