Oil to Carb coming from PCV - Team Camaro Tech
Old Jan 17th, 13, 12:44 PM
USN1969SS USN1969SS is offline
Tech Team
Dave
Default Oil to Carb coming from PCV
I am getting oil thru my pcv hose and into the carb...is this normal? It is not "dripping" out but the tubing is wet. I changed my valve covers to one that had a better baffle but this did not help. A friend said it's no big deal since it is just going down into the intake and burning off. I can't really say if it is affecting performance or not...plugs look ok. I just pulled, disassembled and cleaned carb and did notice some oil in it (just a smidge).
Dave
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
http://www.camaros.net/forums/pictur...pictureid=4730
Old Jan 17th, 13, 01:27 PM
72LS3Z27 72LS3Z27 is offline
Chris
Default Re: Oil to Carb coming from PCV
I had the same issue.5 quarts in 600 miles,lol,with unbaffled valve covers.It seems that around a quart every 500 miles is around the norm for the newer 454 GEN VIs.
See my post for my newest fix.(I'm keeping an eye on it.
Moser 12 Bolt w/3:42s Autogear M-22W Gen VI 454
Old Jan 17th, 13, 03:27 PM
DjD's Avatar
DjD DjD is offline
Dennis
Having the right valve and a good baffle will reduce the oil consumption and using a port in the intake will help keep oil from the carb. I went through a lot of trial and error and found swapping the valve and breather made a big difference. Also keep in mind if your engine is modified you will have to guess at the correct PCV valve
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Jan 18th, 13, 10:57 AM
Tech Team
Dave
Thanks, I guess the only down side is ??? foul plugs ???
Old Jan 18th, 13, 11:27 AM
DjD's Avatar
DjD DjD is offline
Dennis
???foul plugs??? Are you just accepting excessive oil consumption via the pcv valve? If you can't go between oil changes without adding a quart that is too much oil loss to be normal!
With no baffle my 383 was sucking so much oil you could see it drip out the hose without even shaking it. I put in baffles and cut that way down, but still was sucking oil. Changed to a more performance oriented valve and cut down the loss more. Moved the valve to the pass side valve cover and a breather on the driver side and now I can go 2500 - 3000 miles without adding a quart. I never had plug fouling even at the worst oil consumption...
Get a pcv valve for a factory 375hp BBC and try it for a while in each valve cover and check your results, also give it time because any oil already in the hose will take time to be sucked out...
...Dennis
White Wonder
The Nova
Photo Album
Old Jan 18th, 13, 02:47 PM
Everett#2390's Avatar
<Jake 68's Rule
As Dennis suggested, either trying another brand of breather, one having the PCV in the breather helps, or if using the OE design, PCV in a grommet on the cover, you might make a baffle smaller than the width/clearance between the two rocker arms, and JB Weld it in place, use lacquer thinner or alcohol to clean both surfaces, and let sit overnight to cure, helps alot.
Some oil may come from the vapor sucked in, then the mist form droplets.
However, another problem may be too much crankcase pressure as in too much blow-by from the rings, but hopefully unlikely.
If spark plugs are of the proper heat range, they would burn off the oil about the electrodes and not affect them from becoming fouled.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Jan 19th, 13, 10:41 AM
Tech Team
Dave
Thanks for the replies. I'm not using oil, actually never had to add any since I have been driving it nor are my plugs fouling, was just concerned about oil in carb, and didn't know how to curb it. I will experiment with pcv's as suggested.
Thanks again,
Dave
Old Jan 19th, 13, 10:46 AM
DjD's Avatar
DjD DjD is offline
Dennis
Thanks again,
Dave
As I suggested earlier, the PVC vacuum should be coming from a port in an intake manifold runner not the base of the carb... That will clean up the bottom of your carb 100%.
...Dennis
White Wonder
The Nova
Photo Album
Old Jan 19th, 13, 02:02 PM
ROBS6T8's Avatar
ROBS6T8 ROBS6T8 is offline
Robert
On this note Dennis, I just installed another port for my PCV on the intake manifold. If I run the PCV there, #8 runner, won't that just dirty up one cylinder? I have it at the carb now but could switch it back to the intake. Just curious which would be better?
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread http://www.camaros.net/forums/showthread.php?t=180476
Old Jan 19th, 13, 02:18 PM
Fred Ficarra Fred Ficarra is offline
Fred
Robert, DON'T use that port for PCV. It's for static vacuum like brakes and transmission module. The PCV flows vacuum so is MUST be getting vacuum from all cylinders equally, i.e. the plenum.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Jan 19th, 13, 02:52 PM
ROBS6T8's Avatar
Robert
Thanks again Fred. I won't use it and keep it like it is. I have my booster hooked to it.
Old Jan 19th, 13, 03:32 PM
Tech Team
Dave
I have an old Edelbrock Performer manifold and see only one port, a plugged port on the back left runner. It looks to be the same port that Robert is refering to in his pic. The current connection is a port at the base of the carb, see no other way/place for connection.
Old Jan 19th, 13, 03:57 PM
ROBS6T8's Avatar
Robert
Yes, Dave, mine was plugged also. I had my booster running to the back of the carb. I put the Edelbrock fitting in on my AirGap manifold for an extra port. And don't believe Edelbrock about it fitting under a Holley style carb!! It needs a spacer. You can see in my pic that I put a 1/2 inch spacer in so I could fit that fitting in there. If you need part numbers, let me know.
Old Jan 19th, 13, 04:21 PM
DjD's Avatar
DjD DjD is offline
Dennis
I apologize, I have everything; power brake booster (when I had power brakes), RS headlight doors etc hooked up there but the PCV is indeed on the base of the carb... They make different fittings for up to 3-4 lines to connect to the manifold and I am not sure why I was stuck on the PCV being on it!!
...Dennis
White Wonder
The Nova
Photo Album
