| Team Camaro Tech Current Topic: Aftermarket shifter that fits 67 console? | ||
i have a 67 camaro with the 67 console. i do not want to use the original shifter due to it being ugly. i want to know if there is a aft. shifter that will fit in the console without cutting the console up. i am running a 400 turbo. will a 96-97 camaro shifter work? any suggestions would be appreciated
| Sponsored Links | ||
Advertisement | ||
Matt - you will find it is less of a question of what shifter will fit as to which stick will. Hurst aftermarket shifters will fit a 67, but you need the right degree of raked stick to clear the console. Start by doing a search here using the Google option with key works Hurst stick 67 you will find a detailed thread where the sticks and stamp numbers are listed for 67 factory consoles. If you can't find it send me a pm and I'll pull it from my bookmarks when I get home.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear http://69pace.blogspot.com/ |
There have been some done, myself I usually don't reply with do a search but you might have to since I have no idea what the post is called that was showing different aftermarket shifters installed in stock consoles. My personal opinion is most of them look like ugly. I have seen a 68 console sold on E-bay that uses a Hurst gated shifter that looks kick azz but I would never put a 68-69 console in my 67...LOL!!
I just went with a floor shifter and no console.......looks ok until I figure out something else or it grows on me. I can say I like the shifter and how it shifts!! It's nice to bang a gear and not worry about it going up or down more than you want. I will reserve my final judgment until I get carpet and go from there. I know not exactly what your looking for but figured I would post an option since your not in love with the stock shifter. ![]()
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn....... Then, you have enough horsepower." -Mark Donahue My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805 Last edited by Joe Harrison; Jan 21st, 13 at 09:40 PM. |
I plan on using a 68/9 console in my 67 'Bird. I'll use a B&M Quicksilver shifter. Will need to make a new plate to cover the shifter opening. Do some searches on here and Pro Touring. A few people have adapted shifters to the 68/9 consoles and they look pretty good. Unless you want to keep the console stock.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s http://community.webshots.com/album/222472397caZdha |
There is a company that makes a kit that turns your original factory shifter into a ratchet shifter like B&M while allowing for a stock look. The kit has the necessary parts to do a 2-speed powerglide, 3-speed th350 or th400, or four speed automatics like the 700R4.
I'll get the info and post it later. |
This would look good if you could make it fit a 67. http://www.ebay.com/itm/1968-69-CAMA...e07071&vxp=mtr
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler |
thank you but i am looking for something that will fit in the original shifter hole without modifications to the hole or console, i want to say i saw a 96-97 shifter stick in a 67 console at a show but i have slept since then. the ebay shifter is cool but it won't fit the 67 console without cutting
There are other versions of the same shifter that might be adaptable without cutting your console. I don't even know what a 67 console looks like though. http://www.ebay.com/itm/68-69-TRANS-...item4d000229ab
al thats a 67 console that it is attached to. i wonder why they say for a 68-69? that is probably the one i will go with. has anyone used one of these on there rides? how do you like it?
no wait that is a trans am console, looks similar, i will ask them if they have one for a 67 camaro
#11
Those are the consoles I was thinking of. The 67 style looks ok but would look better with the shifter level with the console in my opinion. It looks like mods could be done to make that work. I have thought about trying a 67 with no shift plate over my quick silver and then see what it would take to have a new metal insert fabbed up to fit it using some of the stock parts....basically just the handle coming through. I have not found a cheap enough 67 console to work with though...LOL!!
"If you can leave black marks on a straight from the time you exit a corner till the time you brake for the next turn....... Then, you have enough horsepower." -Mark Donahue My 67 Camaro Time Line http://www.camaros.net/forums/showthread.php?t=211805 |
#12
good luck finding one cheap!!! i just bought the console w/gauges from classic and it was 1,000.00 so i would prefer not to cut on it
#13
PM me if you're thinking of ditching your '67 auto shifter.
#14
if i had it i would let you have it but didn't come with car when i bought it
| Sponsored Links | |
Advertisement | |
