| Team Camaro Tech Current Topic: SBC Aluminum cylinder head recommendation! | ||
Hello,
It's time for me to start upgrading my engine in my Camaro since I have the tranny and brakes all figured out. For starters this year I want to just upgrade the top end of the 355 that is currently in the car. Previous owner states its a 355 with forged internals and a hydraulic flat tappet cam. The current heads are 462 or 492 corvette heads that I will pull off and sell. I want to upgrade to a hydraulic roller and aluminum heads and a performer rpm manifold. The car has a new TKO600 and 4:10 gears with a 26" tall tire. I want more power but maintain drivability. But I like drag racing too. My last two camaros ran 11.90's small block and 10.90's 540. So I like it to be fast. I have used Dart Pro1's in the past on a 383 with a hydraulic roller around .535/.545 lift and that car ran great. I was hoping to try a different cylinder head this time. What recommendations do you guys have for strong 355 with the potential of a bigger short block next year? Are RHS heads any good? Thanks, Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi. |
| Sponsored Links | ||
Advertisement | ||
RHS makes excellent castings.
I would contact Chad Speier at Speier Racing heads in Hays, KS....he has lots of different options that will be right up your alley.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico 1968 Street/Strip Camaro 350 w/PG 1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP Land of the Free Because of the Brave It Takes a Long Time to Grow Old Friends |
AFR's outta the box are hard to beat if you can afford them.
68 originally ss (straight six) 406,Afr210,Bullet solid roller,rpm airgap,QF750,th400,3.73 Eaton posi.11.3@118 |
I've had my eye on a set of these: http://www.speierracingheads.com/profilerecono.htm
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler |
Pro-Filer makes a very good head and they are in your state.
Several options exist for decent 23* heads that would work on your combo. Some mentioned above. RHS, AFR, Dart, Brodix, AllPro, etc. any of these manufacturers have out of the box heads that will work fine for your stated goal.
As an example, 7-8 years ago my 3310 lb Camaro went 11.20's all day with a set of old iron Crane Fireball heads on a junker 408. Remember those old things? LOL. My point is, don't over think it, just get a head and valve train that will compliment your cam profile and performance objectives. Have fun.
1968 Camaro Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph Now: Boost... |
I like the sound of owning a set of AFR heads but I will look at all my options. I need to pick out cam as well. Like I said previously, I have used a Bullet camshaft before and the motor was pretty strong. I think the specs were something like 232/242 @ 050 and 535/545 lift, hydraulic roller. The car ran 11.90's in all stock trim and no traction bars or anything. I ned to start piecing the whole package together and see what I come up with.
Thanks for the replies, Erik
.gearhead.
Your car is looking amazing! I almost bought that car a few years ago before you bought it. I think it was from Indiana or Illinois when it was for sale, maybe western Ohio. Anyways, your doing a great job with it. Do you have any SBC parts for sale at all? Thanks, Erik
Rob 69 Z-28 X-77 HO * DZ Put away * M20 * 4.10 406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200 475 HP, 495# tor Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH |
You and me both, Al. My next street/strip engine will have some of Chad's heads and intake on it. Very impressive pump gas performance for a very fair price imo.
#11
another head to consider is the TFS 200cc
202/160, with mild clean up they will make good power a girly roller around 230s/240s with 1.6 rockers around 600 lift and good springs will make around 500hp
67 camaro 373s: 420 - 641hp HRcam 1.40, 9.90 @ 135 502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7 62 Nova 383/200-4R/12-bolt w 373s 224/224 HR cam 1.57 10.97 @ 121.2 |
#12
67RS502,
Girly cam huh? Can you suggest something more manly that is street friendly? I am looking for a package deal if possible. Thanks, Erik
#13
naaaw
hydraulic roller = girly roller ![]() thats just what we call 'em thats all I run - girly rollers on pumpgas rock! thats why I suggested what I did, it would make good power be streetable and make decent power.
#14
Check out those heads Chad sells....AllPro.... I was ready to pull the trigger on a set before I went LS
![]() Look at that one he just posted too 500+ HP
68 Camaro~ LSx RedЯum <-Pics http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here |
#15
Erik: I have a set of AFR 195 heads on the ZZ430 clone I orignally built for my first '67 Camaro but is now going in to my '55 Bel Air, and with the GM Hot Cam it should be in the same 430hp/400ft.lbs range that GM had with their 430. However, CHP did a 383 build using the RHS 180 cc heads, with 64cc combustion chambers that put our really solid numbers, so I went with these heads for the 327 that I had rebuilt for my second '67 Camaro. I was very impressed with the quality of the machine work and preparation on the assembled RHS heads. If you can swing the AFR heads then I think both are a great improvement to a small block Chevy.
Relax, all right? My dad's a TV repairman, got an ultimate set of tools. I can fix it. |
| Sponsored Links | |
Advertisement | |
