fuel pump pick up - Team Camaro Tech
Old Jan 22nd, 13, 11:50 PM
jerryt jerryt is offline
Default fuel pump pick up
well i got the tank out of my camaro. any tips on how to take out and reinstall fuel pickup. have read post about checking float level. can someone explain this.
jerry
Old Jan 23rd, 13, 05:43 AM
mahunt mahunt is offline
Michael
Default Re: fuel pump pick up
The float IS the fuel pickup.
Undo the lock ring (righty tighty, lefty loosey), pull out the float/pickup, remove old O-ring, insert a new O-ring, insert new float/pickup, tighten lock ring.
Thats it.
Old Jan 23rd, 13, 10:48 AM
cool.
jerry
Old Jan 23rd, 13, 11:06 AM
BPOS BPOS is offline
Al
This video is for an older Chev p/u and is virtually the same as your Camaro. http://www.youtube.com/watch?v=CHxJu...ayer_embedded#!
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jan 23rd, 13, 03:17 PM
tkz69camaro tkz69camaro is offline
terry
Be careful ,not a good place for sparks.
Old Jan 23rd, 13, 05:42 PM
I took off the fuel pick up on my gas tank. The old one was 5/16 line, the new one is 3/8 line. The original pick up sock was gone. I looked inside the tank and sloshed the remaining fuel to see if I could find the sock. I could not find the sock or any contaminates. So I just put the new pickup in the tank.
When I tried blowing thru the line on the tank side it was clogged. No air would go thru. Do you think I should drain the tank all the way and blow it out with compressed air? Or just put the tank back on andput fuel in it and see how it goes? Just looking for other opinions.
Jerry
Old Jan 23rd, 13, 07:10 PM
Vega$69 Vega$69 is offline
Team Member
John
Make sure the line is clear and there is no debris in the tank BEFORE you re-install the tank
69 Pro Tour - LS7/T56 Building
C6ZO6 Vette Lemans Blue
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Jan 23rd, 13, 08:53 PM
Denvervet Denvervet is offline
David
While you have it out I'd for sure dump it and see what comes out.....and have a peak inside
68 coupe ,572,tko
Old Jan 24th, 13, 04:04 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Definitely dump it and clean it out. There's a reason the old one clogged.
You might be surprised what you find in the bottom.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Jan 24th, 13, 12:27 PM
bigblockragtop bigblockragtop is offline
mike
Robmc makes a replacement for the stock pick up I use it because I wanted to go to 1/2" lines without sumping my stock tank. Also it would be crazy not to clean out the tank while it is down. Why drop the tank twice.
Old Jan 24th, 13, 03:05 PM
i agree. i took all the gas and found no debris. then l blew tank out with compressed air. everything looked clean. put in pick up and will install tomorrow. will keep you posted.
jerry
Old Jan 24th, 13, 03:15 PM
HwyStarJoe's Avatar
SEMA ACTION NETWORK
Old Feb 6th, 13, 08:39 AM
well here is a update. I tested the pump by placing a bottle with fuel connected to the inlet. and a empty bottle on the outlet. I spun the motor and fuel flowed. The fuel pick up was also clogged. Had to replace it. And then still had no fuel. So I assume it was the line. So i pulled out the line, and the section that ran threw the front frame some how got crushed. So I cut off the bad part ran some new hose and my car started. One test at a time. Two out of three went bad. Only bad thing was the pump was probably good. Now I can drive my car so I am happy.
Jerry
