Aeromotive fuel tank / fuel system - Team Camaro Tech
Old Jan 23rd, 13, 11:59 AM
jrb70454 jrb70454 is offline
Tech Team
Default Aeromotive fuel tank / fuel system
Hey folks,
I am just about to buy this Aeromotive fuel tank and the rest of their fuel system for my 68 Camaro. http://www.summitracing.com/parts/AEI-18657/
Has anyone used one of these tanks yet or have any thoughts about it? I'm running a 540 with a carburetor. I'm going to use their regulator and do a return fuel system.
Thanks,
John
1968 SS 396
10.7 @ 125 - 3900lbs
(the 396 is under a tarp in the back of the garage)
Old Jan 23rd, 13, 12:06 PM
cool rocking daddy cool rocking daddy is offline
Chet
Default Re: Aeromotive fuel tank / fuel system
What is your concern. Aeromotive is a respected company. One man's garbage is another man's treasure, you know?
69 SS Clone, soon to be Metal Man's version of Fathom Green with white pearl D90 stripes, 355, pocket ported 041 heads, mild hydraulic cam, Demon carb,GW subframe connectors and solid body bushings, 8.5 10 bolt, 2004R
Old Jan 23rd, 13, 03:12 PM
tkz69camaro tkz69camaro is online now
terry
Have you checked TANKS inc. out? They make the tank for a Aeromotive.
Old Jan 23rd, 13, 05:59 PM
Tech Team
The biggest concern I have is I feel like I'm the first one into the pool with this thing. It looks like a great product, but I would love to hear someone say they run this tank, with a carburated motor, in a 10-second street car.
And I have seen the TANKS website- yes, the exact same tank but not the same pump.
1968 SS 396
Old Jan 23rd, 13, 07:34 PM
Chet
Somebody has to be "the first in the pool". Why not you?
Old Jan 23rd, 13, 08:03 PM
R/T R/T is online now
Jack
I am looking at the same set up, but for a 69. Found very little feedback on it. My concern is how well will it work in drag racing (1/4 tank of fuel) with the pump mounted in the front of the tank.
Matthew 22: 37-39
http://i5.photobucket.com/albums/y19...T/IMG_6975.jpg.
Old Jan 23rd, 13, 09:00 PM
sc68z28's Avatar
sc68z28 sc68z28 is offline
"Stick Willy"
I would want a bigger (more gal/lbs per hour) pump.
Larger fuel line, minimum AN8-1/2".
And the pump/ pick up at the rear of the tank in a sump.
JMHO.
I run an Aeromotive Eliminator pump, in the tank (sump pick up) with AN10-5/8" feed line.
My pump is maxed out with a low 9 second car on gasoline, the Eliminator moves almost twice as much fuel as the Stealth 340 in that tank.
---Bill.
1968 Procharged 383, EFI, GF5R 5 speed, 7" two disc clutch
9.10 @148 vid http://www.youtube.com/watch?v=9tK2vx1o0fw
1.28 60' vid http://www.youtube.com/watch?v=1OLzx5jBo4w
Old Jan 24th, 13, 12:18 AM
Tech Team
JMHO.
---Bill.
The size of the pump is another concern for sure! But Aeromotive says this is a "paradigm shift" in fuel pump engineering- with their regulator and all the right components, this will support 1000+hp. (The math supports it.)
There is a baffle in the tank that keeps the fuel from moving away from the pick up, so I'm not too concerned about that. I have a stock style pickup with a mechanical pump that is doing the job now. But the mechanical system vapor-locks easily, especially with winter gas on a warm day- something I have been trying to cure for years... This high-pressure system without a pump bolted to the block will hopefully cure that.
I have my toe in the pool, but damn- the water ain't cheap!
1968 SS 396
Old Jan 24th, 13, 12:30 PM
bigblockragtop bigblockragtop is offline
mike
I have a 496 procharged about 800 plus hp easy I use the stock tank with a robmc 1/2" line and return pickup. The only thing is I make sure I have at least a half of a tank before I tromp it.
Old Jan 24th, 13, 04:14 PM
Jack
Which fuel pump do you use.
Do you have 1/2(-8)fuel line up to the carb?
Matthew 22: 37-39
Old Jan 24th, 13, 06:44 PM
mike
I use a weldon a1000. The Robmc pickup comes with -8 or -10an fittings. I use -8an to the regulator and back. THe regulator is mounted in the engine compartment and have a boost referenced regulator. It regulates fuel flow, it ads one lb ofpressure per lb of boost. I like the weldon or the magnafuel(Puller style) they are both pullers meaning they do not rely on gravity feed(this way I did not have to sump the tank and mount the pump low) and will run without overheating on the street. The weldon was much less $$.
Old Mar 25th, 13, 04:16 PM
Tech Team
Talking Re: Aeromotive fuel tank / fuel system
Y'all come on in- the water is fine! The Aeromotive tank is in and the car is running beautifully. Did it cure my vapor lock issue? Can't tell yet, but rock-solid fuel pressure all the way to high gear & high rpm.
The install was pretty easy. It has been a long time since I wired an electric fuel pump system- crawling around under the dash and snaking wires through the full interior isn't fun, but luckily I have a short memory. The plumbing was simple once we learned how the PTFE fittings worked. The only non-Summit fitting I used leaked. The pump is very quiet- it is all good!
1968 SS 396
Old Mar 25th, 13, 07:30 PM
Denvervet Denvervet is offline
David
Regarding the vaporlock issue...do you have the tank vented? Be a little cautious about returning fuel from engine back into tank. If you cruise around much it can really heat up the fuel in the tank then you have a new problem. Just my $.02 worth.
68 coupe ,572,tko
Old Mar 25th, 13, 08:53 PM
Tech Team
Heat up the fuel if it recirculates? I'm way more concerned that it would heat up dead-headed at the carb! That isn't a theory I had heard. But yes, vented tank. Aeromotive has that all taken care of- there is a vent port and they supply a vent end with a check valve in cast the shiny side doesn't stay up... THAT would be a new problem!
1968 SS 396
Old Mar 26th, 13, 11:34 AM
David
If you do a search on here about over heating fuel ...common problem if cruising any length of time in warm weather with return from engine.
68 coupe ,572,tko
