Looking at an engine tommorrow. Need opinions - Team Camaro Tech
Old Jan 26th, 13, 06:07 PM
mnm99's Avatar
mnm99 mnm99 is offline
Marc
Default Looking at an engine tommorrow. Need opinions
Im going to look at an engine tomorrow and wanted to figure out if its worth my time. This was in a 72 Nova tubbed car. Only used at the track. He sold the car and not the engine. The guy that bought the car had a big block he wanted to use so he pulled it and sold it sepperate. Block code 14016379. It also has stub girtles on the rocker studs. Not sure of the crank. I would have to replace the pistons for sure. He's asking 3k, but im not offering anything over 2k if I decide to do it. I'm going to offer him $1500. He is moving real soon. I think he needs the money. I posted this in the other thread trying to figure out what heads it had. I can't find any casting numbers except AFR on the front in a small stamp. The only numbers I found were 2485 on the inside that were raised stamps. They are angled plug. What do you think
Click image for larger version
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B]
Old Jan 26th, 13, 06:52 PM
ZLP955 ZLP955 is offline
Tim
Default Re: Looking at an engine tommorrow. Need opinions
Originally Posted by mnm99 View Post
What do you think
If he's recovering from a heart attack, go easy on him when making a low offer....
Seriously though, specs read race only, so what are your intentions for this engine?
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA; Now a work in progress.....
Old Jan 26th, 13, 06:58 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Make sure to ask him if it ran on gasoline or alky.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Jan 26th, 13, 07:03 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
Why would you want to low ball somebody just because they are moving and need money. And just had a heart attack?
Heads might be worth close to 1500. If I had it and you offered me that I would tell you to...
Well you know...
Would you want someone to treat you that way?
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Jan 27th, 13, 02:44 AM
mnm99's Avatar
Marc
Well you know...
OK..Sorry I worded it that way. I understand how it sounded... I meant he sold the car and wasnt racing anymore because hes retireing, because he had a heart attack and is moving out of state soon to be with his some. I wouldn't take advantage because of the heart attack. Because hes moving and needs to get rid of it was my main reason for the low ball.
Old Jan 27th, 13, 09:12 AM
Everett#2390's Avatar
<Jake 68's Rule
1978-85 14016379 350 - - - car, truck
FYI
Stud girdles because of the lift - 0.760"
Check to see, or ask, if rocker arms have been backed off preventing springs from losing pressure.
Ask for cam card, balance sheet.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Jan 27th, 13, 09:38 AM
mnm99's Avatar
Marc
FYI
That's the only info I have. I looked at it today and made a final offer of $2100 and he declined. The heads are 220s for sure. Remember I would have to tear it down anyway to change the pistons. Most likely change the cam too. He has a brand new msd dist in a box too. Maybe if I offer $2500 with the dist hell go for it. Seemed pretty firm though.
Old Jan 28th, 13, 04:50 AM
mnm99's Avatar
Marc
Nope..$2500 and he'll think about it.
Old Jan 28th, 13, 04:50 PM
X-77 keith X-77 keith is offline
keith
Why do you have to replace the pistons? Keep in mind after cam
bearings " crazy if you dont replace during tear down " Machine shop labor, oilpump, pistons, gaskits,and what ever else you may need it will prob be a 4K deal.
Old Jan 29th, 13, 03:58 AM
mnm99's Avatar
Marc
See sig...350 TWIN TURBO . 12.1 is a NO NO with forced induction. I was quoted 3K using JE blower pistons. Balancing, bearings tear down ect....complete
Old Jan 29th, 13, 10:53 AM
zman1969 zman1969 is online now
Rich
your going a long way to put it back on the street, that engine needs a race car! save yourself the headach and start with something more useable
69 R/S Z/28 302 4.10 X33 D80 late 09C
(looking for date coded 12 bolt BU)
69 T/A clonification LS6-6speed under construction
69 Nova SS retirement project
99 Firehawk
64 Chevelle wagon
Consciousness: That annoying time between naps.
Old Jan 29th, 13, 11:37 AM
Michael Gekko
Unless it's a 13-1 or higher CR you can probably change the cam to something not as wild and yet bleeds off enough cyl pressure so that it can be driven on pump gas or a mix of race gas and pump gas.
Old Jan 29th, 13, 02:52 PM
bigblockragtop bigblockragtop is offline
mike
Twin turbo start from scratch. Why spend the money twice
Old Jan 29th, 13, 03:56 PM
mnm99's Avatar
Marc
I know it's useless for me NOW. My plan is to break it down and use the heads, rocker arms, crank and rods. Heads alone would cost me $2000 at least. He had them ported with flow numbers, The crank rods are Crower (forged). Going to use them. Intake I could sell($100), Carb,Barry grant I could sell($150) Hamberger oil pan sell($100) He's throwing in a NEW MSD distributer Sell ($200). Block I could sell ($400) Electric waster pump Sell sell ($125) Valve covers sell($125)So far thats ($1050) . I got the motor for $2800 so - $1050 thats $1750 for 220 AFR worked heads, Roller rockers, Forged crank and rods. I'll have the crank and rods balanced and prepped. Maybe sell the heads for $1200 and buy new 195AFRs for $1500. A new Dart Block cost $1400. Any machine show wants at least that to prep the existing block anyway. So might as well buy a new block. I have a plan and in no rush...
Old Jan 29th, 13, 06:16 PM
keith
Sorry abou the question about the pistons,your "sig" says twin turbo, but that does not mean that is what you are going to do with the engine in question, not stated .That is why I askd. I wishyou luck on sellig all of the parts for he prices you listed. Four bolt 010 vrgen blocks are selling for $150.00 here in Virginia.
