| Team Camaro Tech Current Topic: Burnouts unecessary? | ||
| Bench Racing Stories, cruising and more. |
Are Burnouts necessary in most cases? i'm thinking no.
Your thoughts? |
| Sponsored Links | ||
Advertisement | ||
It depends on the car. Back when my car only ran mid 12's on drag radials I would just spin them enough to clean them off. As I started going faster a burnout was definately needed.
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Total Seal rings, hand ported AFR 210 heads, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .660" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 8" converter |
I rarely ever do one on the way to the grocery store.
Robert '69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis '67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt '77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25 TC member #18 |
They are cool though when done right!
In what context? At the track? Street tires or slicks?
i'm saying for MOST cars at the strip short of the pro or alcohol classes (although i'm thinking they may not need it either).
i'm thinking it would be better to get a wider tire than burn the one you got in order to make it sticker---it's too marginal. A larger tire would be more consistent and put less stress on the drivetrain if no burnout required. |
The generally accepted guideline at a drag strip is; racing tires = burnout (for the reasons already stated), street tires go around the water and no burnout. Now what happens after that (the race itself) is a totally different thing, the less spinning the faster the car will run but not spinning isn't necessarily possible with lots of power...
When the tire is warm it sticks to the VHT better....but yes, most of the time a 10sec. "dusting" is fine. All comes down to the tire, track temp, and track prep.
68 Camaro~ LSx RedЯum <-Pics http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here |
Nothing like the smell of rubber in the afternoon...or is it napalm? Remember that line?
capt |
Oh...and it looks cool too
#11
Doug and Dennis pretty much hit it on the head.
But who cares they are cool!
67 R/S convertible Nantucket blue deluxe interior orig.http://s63.photobucket.com/albums/h152/67ss/The%20pair/ 67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91 http://www.youtube.com/watch?v=LFLC2...eature=channel |
#12
If it's a tire that gets sticky, not a street radial, yes it helps. If the car they are on is slow and won't spin the tires anyway no point obviously.
That said even in the really fast drag classes guys typically seem to over do it, all they need to be is up to temp, not too hot not cold either.
Sean 1968rs, formerly a 406 sbc, 354" SB2.2 coming soon... "Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari |
#13
If racers didn't need to heat up and wear the tires I doubt they would....those slicks aren't cheap. Have you ever actually seen the size of the more popular tires used on drag cars? Go pick up a mounted Goodyear or Hoosier 33x16 tire, then look at the wheel tubs in the car that it is going on, and tell me where and how you are going to fit bigger tires on the car? And many associations prohibit running larger tires. Stock Eliminator racers are limited to 9 inch wide tires and Super Stockers are limited to 33x14.5. And others are limited to 275 radials and 10.5s. Nitro cars use the burnout to put heat in the engine....funny thing about that nitro, it makes lots of power but it's hard to light it and if the engine doesn't have some heat in it then it just isn't going to work period. An example is the fact that A/ fuel cars start on gasoline and idle for a bit before pulling into the water and switching over to nitro.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico 1968 Street/Strip Camaro 350 w/PG 1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP Land of the Free Because of the Brave It Takes a Long Time to Grow Old Friends |
#14
A big mistake with a burnout is not all tires are created equal. Drag radials and slicks are made to heat up or to temper and stay soft. Street tires will glaze and temper and get hard and will ruin the tires quickly. Not that I am a tire guy but I found this out from a tire guy. Doing a burnout from a 40 mph roll is rather enlightening though, can you say adrenalin rush.
#15
is a car that's capable of doing a burnout necessary?
you don't plan sincerity. you have to make it up on the spot. wanna hear about 20 years ago when i was too smart to know any better? |
| Sponsored Links | |
Advertisement | |
