Lowering blocks 1" - Team Camaro Tech
Old Jan 27th, 13, 11:29 AM
Nick 69 Nick 69 is online now
Nick
Default Lowering blocks 1"
Hi
After have changed "all" parts in my suspension last year I felt that the rear end was a bit high and I want to get it down a bit.
Is there any company selling lowering blocks ? I have tried searching but canīt find anything. I could of course make some ones myself, but Í thought I should check if anyone selling them.
Nick
Old Jan 27th, 13, 11:43 AM
BPOS BPOS is offline
Al
Default Re: Lowering blocks 1"
Pretty car - love the wheels! http://www.speedwaymotors.com/search...ng-blocks.html
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Jan 27th, 13, 11:52 AM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is offline
Steve
If you have very much horsepower, go with cast iron not aluminum blocks.
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Total Seal rings, hand ported AFR 210 heads, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .660" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 8" converter
Old Jan 27th, 13, 12:24 PM
TJS69 TJS69 is online now
Tom
Smile Re: Lowering blocks 1"
Summit Racing
http://www.summitracing.com/search?k...20blocks&dds=1
Speedway Motors
http://www.speedwaymotors.com/Garage...cks,54439.html
http://www.speedwaymotors.com/Speedw...ocks,3353.html
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Jan 27th, 13, 01:36 PM
Nick
Thanks guys
I must have been a bad searcher, couldnīt find any before.
Steve
I donīt have enough power (as always )
But maybe in the future. Where could you find the iron ones ?
And is it a big problem with alu ones and bigger engines ?
But for now will the aluminium do.
Old Jan 27th, 13, 01:40 PM
Steve
Originally Posted by Nick 69 View Post
Steve
The aluminum will be fine then. Most places that sell the aluminum ones have cast iron.
Old Jan 27th, 13, 02:23 PM
Al
I only needed a 1/2" block so made it from steel plate. If you can find a longer center pin for your springs (the pin is actually just a bolt with a funny head) you can just bolt the lowering block to the top of the spring with the new pin.
Old Jan 27th, 13, 02:28 PM
Kunihiro Kunihiro is offline
Allen
There is another option, aside from lowering blocks.
I know your title says "one inch", but have you thought about replacing your multi leaf springs with a new set from "Global West?" The only drawback is that their multi leaf springs will lower your car 1 1/4".
http://www.globalwest.net/67-69-cama...ckle-kits.html
Just a thought.
Allen
Old Jan 27th, 13, 02:33 PM
Fred Ficarra Fred Ficarra is offline
Fred
Hi
Nick
Nick, true, everyone's taste is different, but,,,,,,,, your car is drop-dead gorgeous just the way it is. Jaw dropper too.
So, how's the weather in Sweden?
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Jan 28th, 13, 12:38 PM
Nick
Al
I had planes making them my self. Problem is that I live in a small town and itīs problem getting hold of material to build. And for the price of ten dollars (as they cost) I have problem motivate me
Allen
I have brand new Hotchkis multi leaf with 1.5" drop, and want another 1"
Fred
Thanks, itīs "quite" ok in that angle. A side photo would have shown the reason for lowering some more a bit better.
Itīs just that extra touch up.
And the weather is is is.....cold. We have had -4 F for a while, but today it raised to 32 F
Old Jan 28th, 13, 01:05 PM
freezined freezined is offline
Ed
Great looking car Nick!
Tell us a little more about it, I'm interested in your spring, tire and wheel specs.
A side pic would be great, but from this angle it looks drop-dead gorgeous just the way it is (thanks Fred).
Old Jan 29th, 13, 10:41 AM
Nick
I have Hotchkis upper arms and springs (1907F) and Protech adjustable dampers. But you cant "copy" the height by adding same parts. I had a plan of using the stock lower arm, but when putting the car together it felt wrong to use the stock arms (a bling ting ). Problem was I had empty my pocket on all the other parts so went a cheaper way and bought the "chinese" arms. But when taking the car down from the stands it felt like it went thru the floor . It was standing on the bumpstops. So I had to cut the spring cup loose and raise it 30mm and the weld them on again.
At the rear I have Hotchkis multi leaf (1.5" drop) and Protech adjustable dampers.
Wheels are Image Wheels, 3piece, 8 and 9.5 x 17"
On this photo you can see it a bit better, even if itīs not a perfect showing photo.
Old Jan 29th, 13, 11:08 AM
Tom
The stance looks perfect to me. I like a little bit of a rake, just like that. I believe that is the stance that Hotchkis was going for.
How about adding a front coil spring spacer to bring the front up ?
2 options, but I like it as is.
Old Jan 29th, 13, 01:03 PM
Ed
Thanks for all the info Nick. I could maybe see dropping the rear a touch, but I also like a little rake. I'd be driving it as it sets with a big smile.
Old Jan 29th, 13, 01:22 PM
Gbauer Gbauer is offline
George
Honestly I agree with others here: I like it as-is. Very nice stance. Looks agressive and doesn't look raised up in the back too much. If you drop it an inch I think it might look like the front is too high.
1968 Base hardtop 250... for now
Camaros.net - Đ 2009 AutoForums.com
