| Team Camaro Tech Current Topic: Voltage Regulator drawing power | ||
| Electrical & Wiring Troubleshooting electrical. |
New wiring harness all new switches and relays every
were on this restoration and battery is dying after 2 days did the test light trick and found that if I unplug external voltage reg. the light goes out installed new one same thing any ideas 69 RS |
| Sponsored Links | ||
Advertisement | ||
Can you confirm that you are running a factory 1969 Camaro External Regulator?
Jeff G. |
first one is the original 2nd NAPA
test light glows even brighter with the NAPA brand ,dim glow with original one . I hate hunting down this kind of stuff
The reason why I'm asking to make sure you don't have a 1 wire alternator and be done with external regulator.
Jeff G. |
no its all factory replacement harness
he's not talking about the harness he's talking about your alternator. How many wires go to it?
Jason 2010 Camaro 2SS/RS - 1968 Camaro - 2000 Ford Exploder |
I plug with 2 wires and 1 red wire to post . IT is not a one wire to alt. set up It has a external voltage regulator.
Ensure wire color of new VR plug matches OE/old VR regulator and at alt connector, blue wire to F terminal and white wire to R terminal.
With test light in place, connect VR. Unplug alternator, both the two-wire plug and BATT wire. Light still on, bad VR. Light off, bad alt.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
I will give that a try and get back to you THANKS
#11
If its an external regulated alternator (original type) then make sure your new Voltage Regulator is the VR715 model...its electronic and much much better to use than the old 'points' type unit.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r "There will come a time when you believe everything is finished, That will be the beginning." Louis L'Amour Photos for viewing Learn How To Post Pics here |
#12
The new one is electronic . I have to check now and see if its a bad or alternator I just had it rebuilt since it was the orginal one for the car.
#13
Just to let every one know it was the key switch I had key pulled out and didn't notice that it was turned back slightly to acc. mode even with key out so I clicked it up were it should have been and no more power draw all is good
| Sponsored Links | |
Advertisement | |
