delphi 670 steering gear question - Team Camaro Tech
Old Jan 28th, 13, 07:07 AM
Brokeguy68 Brokeguy68 is offline
Casey
Default delphi 670 steering gear question
Hello everyone.
I’ve been restoring a 1968 camaro for a few years now and im getting into some more specific parts of the assembly.
im trying to make the car handle decently.
in the rear i added the DSE staggered 4 link kit with coil overs. Also, Poly body mounts In the front. i added upper and lower DSE control arms and 2 inch lowered hotchkis springs and koni shocks as well as 2 inch ccp drop spindles. Now I would like to update the steering. I'm looking at the DELPHI 670 steering gear. From what I under stand I need a new rag joint.
Will I need different Power Steering hoses? Also will my PS pump be able to pump enough pressure for the new gear? Is it worth it to go with a cheaper power rack and pinion?
I guess I'm just looking for some general information on the subject.
Thanks in advance!
Old Jan 28th, 13, 07:37 AM
67Rally's Avatar
67Rally 67Rally is offline
Brent
Default Re: delphi 670 steering gear question
Originally Posted by Brokeguy68 View Post
Hello everyone.
Thanks in advance!
I converted from manual steering to PS when I first got my Camaro. I now have a delphi 670 box in my '67. I was able to use the stock PS hoses and a '69 PS pump (I have a long water pump). You will need a new rag joint. The new pump should come with some inserts (where the hoses attach) that look like little metal mushrooms. If it doesn't, you will need them. My box didn't, so I ordered the inserts from Lee Mfg.
It's a great box, and makes a world of difference.
Old Jan 28th, 13, 10:26 AM
Casey
seems pretty straight forward. i like the sound of that!
i guess ill order today
Thank you very much!
Old Jan 28th, 13, 04:21 PM
77thor's Avatar
77thor 77thor is offline
Fred
Wait... you have drop spindles AND lowering springs?? Have you put that car on the ground with a fully loaded suspension yet?
Read this info on drop spindles... http://pozziracing.com/first_gen_sus...geome.htm#Drop Spindles
You may want to re-think those.
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Jan 28th, 13, 09:03 PM
davidpozzi davidpozzi is offline
David Pozzi
& this thread in our forum: http://www.camaros.net/forums/showthread.php?t=132682
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Jan 31st, 13, 01:31 PM
Nate67 Nate67 is offline
Nathan
David,
Is your website down? I've tried a few different computers and none can find your site anymore, It's tragic!
Old Mar 15th, 13, 06:21 PM
Joe G Joe G is offline
The website works for me...........
Joe G
69 Coupe; ZZ430; TKO600; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Carrera coil-overs front; Classic AutoAir AC and power windows now cuz I'm old and lazy!
