1971 Z28 LT-1 Block, Heads, Valve Covers - Team Camaro Tech
What's it worth? & ebay discussions
Old Feb 4th, 13, 01:40 AM
sparkoft sparkoft is offline
Steve
Default 1971 Z28 LT-1 Block, Heads, Valve Covers
Hello,
I was told in another forum that this is where I should post this question. If this is not the right place I apologize.
I have a bare 1971 LT-1 block with heads and the LT-1 valve covers. i bought it back in 1976 and ran it in my 67 chevelle ss. It has never been bored. It has the extended main bolts that support the windage tray and the heads are the large chamber 202 intakes. screw in rocker studs with push rod guide plates. I was wondering what they might be worth?
Thanks,
Steve
Old Feb 4th, 13, 09:34 AM
Vintage 68's Avatar
John
Wink Re: 1971 Z28 LT-1 Block, Heads, Valve Covers
The Suffix numbers on the front of the block would be needed to give you an even close 'guesstimate'
Also needed would be;
Is this an '010' block?
Is the Forged Crank still with it?
What Head number(s).
Any work done to any above ...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Feb 4th, 13, 10:30 AM
firstgenaddict firstgenaddict is offline
James
Default Re: 1971 Z28 LT-1 Block, Heads, Valve Covers
If you could mate it up with the original car it would be the best and most lucrative for the both as well. In that case assuming the dates and numbers and etc I would easily give $3000. If my car was something real special M22 RS Z in nice colors etc then I may pay more as the increase in value of the car would be significantly more than 3k.
However if it just an engine close to a cars build date it is just that, close, in that case it may be worth 1500-1800 outside.
James
"Collectin' Camaro's since only Rednecks Drove them"
https://picasaweb.google.com/1123922...28_Restoration
Old Feb 4th, 13, 03:20 PM
Steve
Here is a little story on how i acquired the engine. Way back when I was in High School I worked as a VW mechanic half days and school half days. I was taking a two hour automotive class in high school and needed a project. One of the mechanics i worked with said that he had a 71 z28 and he had spun a rod bearing while racing. he said that when he pulled the engine that it only had 30,000 miles on it. i needed a project and he wanted to get rid of the engine so i bought it for 250.00. i rebuilt the engine in high school and installed it in my chevelle. i believe him when he said 30,000 miles because i remember when i pulled the pistons there was still cross hatch in the cylinders. i do know that it has a standard bore and when i put the engine back together i had the heads milled .010. a couple of years later i ended up spinning a rod bearing myself so i pulled the engine and sold the car. the block was never damaged it just has surface rust from all these years. i gave the weiand intake and holley double pumper to my brother who had a 70 ss camero. about 15 years ago i took the block and heads to a machine shop because i was going to rebuild it. long story short the whole thing came up missing. i had to dig through a pile of blocks and heads to find them. the pink rods i could not find im sure one of the guys that worked at the shop took them. the guy i bought the engine from showed me pictures of the car and it was a dark green z28 from ogden utah. i remember looking the numbers up and everything pointed to a 330 hp engine. maybe the car is still on the road who knows. i will get the numbers and post them. Thanks for all of your input.
Old Feb 4th, 13, 09:36 PM
Steve
Default Update: 1971 Z28 LT-1 Block, Heads, Valve Covers
Hi,
Here is an update on the casting numbers.
Back corner by the bell housing. (3970010) It is a 010 high nickel block.
Front tab after the vin. (V0309CGP) 330 hp LT-1
Head casting numbers on both heads. (3973487) large chamber 75cc 2.02 Intake 1.6 exhaust used on 71 & 72 350 LT-1 the heads were milled ten thousands back in 77, other than that no work has been done on the block.
Thanks,
Steve
Old Feb 5th, 13, 08:50 AM
Vintage 68's Avatar
John
To most it's just an '010' 4" SBC ...
To the person restoring the original vehicle it was installed in - if it still even exists - it the OEM installed unit and worth more ... if most of the identifiable parts come with it.
The fact that the heads are already milled (straight or angle?), the HD rods are missing, the crank use in unknown and by this time a clean-up bore, and proper prep work, would be required to have a fully functional and dependable unit -I would count those as non-possitive reasons to pay more for this block if it wasn't going into a very nice 'numbers' restoration of the original vehicle.
"IF" - I had the vehicle I would offer a replacement block (machined or not - your choice) for you to build and up to @$3K for it.
'IF' - I just had a 71 'Z' and was looking for a date/Suffix correct block I would think it would be worth a 'couple $K' at most. And a 'trade' block if you wanted one ...
Here is a comparative 71 Suffix - Click image for larger version
Name:	Suffix 71 V0130CGP Z28.jpg
1968 Convertible
Some trucks
Old Feb 5th, 13, 10:15 AM
Steve
Thanks for the information.
Steve
