Headers Installation - Team Camaro Tech
Old Feb 12th, 13, 08:20 PM
LT1FUN's Avatar
LT1FUN LT1FUN is offline
Norm
Default Headers Installation
This may be a dumb question but I have never had a car with headers before.
Can a 350 small block engine be installed into the engine compartment with the headers already bolted on to the engine? The car is a 69 Camaro with no power steering. I am looking at buying the Hooker Competion 2451 headers.
69 Camaro SS X55
70 Camaro RS/Z28
Old Feb 12th, 13, 09:02 PM
68rs406 68rs406 is offline
Sean
Default Re: Headers Installation
No.
But it is wise to at minumum lay the driver side header in place (against the fender well that is) and lower the engine in next to it. The Pass header can usually be installed after the engine, but the driver side is usually a major PIA after the engine is in.
Sean
1968rs, formerly a 406 sbc, 354" SB2.2 coming soon...
"Aerodynamics is for people who don't know how to build engines" - Enzo Ferrari
Old Feb 12th, 13, 10:21 PM
mjlynch71 mjlynch71 is offline
Jerod
I put in a new 350 2 years ago in my 1969 Camaro, no power steering, and has a 4 speed. Have Hooker headers, the Z-bar took some time to install, but the passenger side header rear most header bolt by the heater core is impossiable to get at and the car is non/AC. Finally got it but took 30 minutes for one bolt with 12pt ARP. Next time before the engine is all the way on the motor mounts, I am going to tighten that bolt. If anyone else has any idea on that bolt, please share it. Took a Snap-ON offset wrench and had to grind down the outside of the closed end to get it to fit, a stubby one will also work. Thanks, Jerod
Old Feb 12th, 13, 10:35 PM
BPOS BPOS is offline
Al
It depends on the design of the header. That bolt on mine was simple as the tube comes straight out and I can put a socket on it easily.
12pt header bolts are a bad idea in some spots - you can't put an open end wrench on them. ARP makes a nice SS header bolt with a 6pt 3/8" head.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Feb 13th, 13, 04:03 AM
gphusker gphusker is offline
Greg
Originally Posted by 68rs406 View Post
No.
This ^. Drivers side should be in place in the engine compartment. Pass side can go in later.
As for the bolt discussion in the other post, I use allen head bolts on all but 2 of mine. On those 2 I use the 6 point 3/8. They are all fairly easy to get to except those 2. I have Hooker Super Competition 1 3/4 on my 350.
My 69 Build thread : http://www.camaros.net/forums/showthread.php?t=211427
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
Old Feb 13th, 13, 04:42 AM
Everett#2390's Avatar
<Jake 68's Rule
Good suggestion by Sean, lay a blanket on the inner fender if headers are coated preventing scratching.
I used 1 inch long hex head header bolt and a crowsfoot wrench with extension.
I did have a flea market 7/16" box end wrench ground on the outside of the box end for clearance and worked very well, but I have misplaced it......
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Feb 13th, 13, 05:04 AM
zdld17 zdld17 is offline
Don
Whats wrong with installing from the bottom up. This has always worked for me. Use the small 3/8's head 6 point bolts. Always worked for me. Be aware that the Hooker 2451 has been known for driver side collector hanging down too low , once installed.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Feb 13th, 13, 05:45 AM
mahunt mahunt is offline
Michael
x2 on 6pt header bolts.
Old Feb 13th, 13, 07:38 AM
Fred Ficarra Fred Ficarra is offline
Fred
Always 6 point. I've got a complete set of used ARP 12 points available for any masochists out there.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Feb 13th, 13, 08:02 AM
mike's blue67 mike's blue67 is offline
Mike
I have taken my engine in and out a couple of times. I can install it with the passenger side header on the engine. The drivers side i have to push in from under the car. I use percy's locking header bolts and have no issues installing the bolts. Good luck
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
Old Feb 14th, 13, 04:38 PM
LT1FUN's Avatar
Norm
Thanks for all the suggestions.
69 Camaro SS X55
70 Camaro RS/Z28
Old Feb 14th, 13, 05:11 PM
keithl1967 keithl1967 is offline
Keith
I installed my headers after the fact as well--driver side has to go in from the bottom, before clutch linkage...Passenger side can go in from the top--I used a crows foot, and some foul language to get that rear header bolt in...
Keith
1967 Camaro
Bought it in 1994:
230, PG w/ 314K miles!
Today:
383, Dart Iron Eagle heads, Eddy Vic Junior, Holley 750 DP--450HP+
Muncie M-20
GM 8.5, 3.73 posi
Old Feb 14th, 13, 10:35 PM
Jerod
If I had put the passenger side header on before the engine was all the way in, it would not have been an issue except for the heater core box. Thanks, Jerod
Old Feb 14th, 13, 10:52 PM
Steiner Steiner is offline
Steiner
ARP makes a set of 5/16" hex header bolts. I'm in love with them.
If you have a driver side dipstick tube the header is that much more fun. I put one of those dip sticks that goes straight into the block in one engine because of that. Just couldn't check the oil if the car was hot without an oven mitt.
Like everyone said, with the engine out it's cake. Blanket or towel draped over the stuff on the side and use a couple pieces of electrical wire to tie the header off to the side. Once the engine is almost in and dangling you can get the header in place with a couple bolts.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Feb 14th, 13, 11:04 PM
Al
When you're done bolting your headers on your 69 with power steering you're going to have one really cool looking 3/8-16 bolt left over with a 3/8 or 5/16 head. It makes a great distributor hold down bolt (use a washer under it)
