| Team Camaro Tech Current Topic: less expensive option than lee 62420 for conversion | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
i have 67 camaro with third gen conversion. needing the coupler. I have read posts about other couplers and this is what i have found on couplers that MIGHT work.
dorman #31011 $41.79 lee #62429 $79.00 lares #200 $20.00. big differences in prices. any major differences quality and fitment? or is it with paying the almost 100.00 with shipping to Lee's. will the others work just as well. looking for a bolt on application with no mods.
1967 Red/Red RS/SS 350 4 speed |
| Sponsored Links | ||
Advertisement | ||
I used the Lares in my upgrade.
It seems to be a quality part. No issues.
1969 Camaro SS 350, M21, 12 Bolt Posi |
There is a GM part, I believe it was a van application. Did you read the info on David Pozzi's site? I will find it and link here...
Eric 69 'vert project big block/TKO 600 RR 68 'vert driver RS clone -- gone! |
Pretty much anything GM from 1979 up will work. I think even pickup rag joints work 79-87 & perhaps even newer. GM went to Saginaw fittings and the small PS shaft size on everything, cars & pickups around 1978 or 79. I have seen them in the store in the "help" brand which is Dorman or Motormite. There is a similar but larger OD version rag joint that works but is bulky and may rub the frame in some applications.
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com 67 RS 327 original owner. 1965 Lola T-70 |
I think Lee sells the GM part which is why it's expensive. Either one of the others will work. I have the Dorman one as I was not aware of the Lares at the time.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
I used one from a 79 Chevy Truck and it worked perfectly. I think it was between $20-$30.
My 69 Build thread : http://www.camaros.net/forums/showthread.php?t=211427 1995 Z28 (sold) 1987 Iroc-Z (sold) 2005 350Z (sold) |
These production flex coupling assemblies will adapt a power gear with a 3/4 diameter input shaft to your older Camaro.
1977-82 C/K (2 and 4WD) Pickups 1977-78 Camaro, Firebird, & Nova 1979 Nova 1983 - 86 C (2 WD) Pickups Jim |
On my 69 I used the lares# 200 on a used 3rd gen box. It worked perfectly. Came with all of the needed bolts. It was like $25 on Amazon.
Good luck! Ted |
The Dorman part that I purchased had the flat spot machined in the opposite position that it should be in. Returned it and found a different one, dont know what brand it was.
69 plain jane 383,TKO 600, 10 bolt mono 3.08 w/caltracs, TT2's 17"x9.5 rear 17'x7 fr. Goodyear F1 275/40/zr17,215/45/zr17.QA1 coil over. Speed tech uca/lca. March ultra serp. |
| Sponsored Links | |
Advertisement | |
