69 cowl induction throttle arm - Team Camaro Tech
Thread Tools Display Modes
Old Feb 14th, 13, 06:20 PM
Rodney21 Rodney21 is offline
Rodney
Default 69 cowl induction throttle arm
Hey guys, I have an original 6 cyl car that now has a SB 400. I bought all the components to make the cowl induction hood operational but I am not sure how the throttle arm attaches to the accelerator pedal. I am currently running a throttle cable and the accelerator rod that goes through the support bracket mounted on the firewall is not long enough to mount the throttle arm to. It is barely long enough to put the E-Clip on. Do I need a different accelerator setup or will this even work with a cable setup? I'm stumped on how to attach this arm to the pedal.
Old Feb 14th, 13, 08:42 PM
Steiner Steiner is offline
Steiner
Default Re: 69 cowl induction throttle arm
Six cylinder and V8 have different throttle assemblies. Not sure what all you've got now but here's a list of different setups.
http://www.rickscamaros.com/catalogs...=12&q=rod+thru
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Feb 14th, 13, 09:12 PM
Rodney
Here are pics under the dash and of the firewall.
Old Feb 14th, 13, 09:21 PM
Rodney
I don't have enough space to post the Firewall pic
Old Feb 14th, 13, 09:38 PM
Rodney
Firewall
Old Feb 14th, 13, 09:42 PM
Steiner
I think you may only need the $34 thru firewall accelerator rod for a V8.
'69 Camaro
500hp/538lbft
www.cmengines.com
Old Feb 14th, 13, 09:48 PM
Rodney
Thanks. That was what I was thinking but I'll need to weld the cable arm onto it.
Old Feb 14th, 13, 09:52 PM
Rodney
Under dash
Old Feb 14th, 13, 10:05 PM
Steiner
You shouldn't need to weld anything. The new throttle arm (under hood) just clamps to the new accelerator rod. Then you need the linkage and little bushings for a few bucks to connect between the carb and new throttle arm. You will no longer use a cable.
If you wanted to retain the six cylinder accelerator rod and cable operated throttle, you could use a nitrous throttle switch mounted inside the car instead of the one that mounts using the new cowl induction throttle arm, and not use the new arm at all. All you're looking for is a switch to make under full throttle.
'69 Camaro
500hp/538lbft
www.cmengines.com
Old Feb 14th, 13, 10:25 PM
Rodney
I appreciate all the help. I've looked through a bunch of catalogs and ebay and can't seem to find this linkage.
  #11
Old Feb 14th, 13, 10:42 PM
freezined freezined is offline
Ed
gas pedal and arm for cowl hood
http://www.ebay.com/itm/1969-Camaro-...263579&vxp=mtr
cowl switch
http://www.ebay.com/itm/1969-Camaro-...c92baf&vxp=mtr
You'll also need linkage from arm to carb, groment, wire harness and relay. I'm sure someone has this in a kit, just not finding one at the moment.
  #12
Old Feb 14th, 13, 10:51 PM
Rodney
Thank you. I've got all the cowl induction parts. I was just missing connecting the throttle arm to the carb. I've for an edelbrock carb and intake so I'll have to figure out how to make this linkage work. I really appreciate all of your help.
  #13
Old Feb 14th, 13, 11:04 PM
Steiner
Here is the grommet that goes in the throttle arm. You may need two, one in the arm and one in the carb.
http://www.rickscamaros.com/camaro-c...1967-1969.html
I'm using this for a throttle linkage but my throttle setup is similar to a Holley. There are universal ones as well that you just bend as needed (carefully) although this one can be bent a tad.
http://www.summitracing.com/parts/oe...t/model/camaro
'69 Camaro
500hp/538lbft
www.cmengines.com
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: 69 cowl induction throttle arm
Location
Location
First Name
Human Verification
