Installing tubular a arms front+rear shocks, springs and a sway bar - Team Camaro Tech
Old Feb 14th, 13, 11:13 PM
69GreyGhost 69GreyGhost is offline
Anthony
Default Installing tubular a arms front+rear shocks, springs and a sway bar
Hey guys, I am thinking of installing my suspension on my own. I have the infamous e-bay arms, moog springs # 5536, kyb rear shocks bilstein front shocks and a hotchkis fron sway bar. I installed my tubular upper a arms on my 72 challenger and changed the shocks myself so I have some experience on this type of job but I havent done anything to my gen one camaro. How difficult are the tubular a arms to install? I assume if I am doing those the springs and shocks will be apart of the reconstruction? What do you guys think? Will I have to remove the fenders or anything else? Thanks in advance for all the help and guidance guys. Also I know the slugs in those arms were bad, does anyone know a good replacement I can use and have a link or a part number? Thanks again guys.
69 Camaro coupe project link http://s1278.beta.photobucket.com/us...ghost/library/
Old Feb 15th, 13, 06:57 AM
77thor's Avatar
77thor 77thor is offline
Fred
Default Re: Installing tubular a arms front+rear shocks, springs and a sway ba
Forget the KYB rear shocks and go with Bilstein's all the way around. That way you have a matched set.
The project is quite a bit of work but very doable. Just be careful removing the old springs.
You may want to buy or rent a spring compressor.
There is no need to remove fenders.
Slugs? Do you mean bushings??
1969 Camaro SS 350, M21, 12 Bolt Posi
Old Feb 15th, 13, 07:33 AM
ROBS6T8's Avatar
ROBS6T8 ROBS6T8 is offline
Robert
Anthony, have you done a search on the "e-bay" arms? There was a lengthy one where someone actually found a place to get new slugs.
You can make this a DIY! Like Fred said above, be safe and rent a spring compressor. You'll see or hear of people doing it without, ignore them. It's only a few bucks for the day!
Tires and brakes will be removed. Shocks will be R&R.
Make sure you get the springs seated in the pockets and definitely make sure you get the sway bar in while the suspension is apart!! I was able to get it in without, don't ask me how because I couldn't do it the second time.
The "search" function will work here also. Next time you're at the auto parts store, pick up a Chiltons. It will help a ton also.
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread http://www.camaros.net/forums/showthread.php?t=180476
Old Feb 15th, 13, 07:35 AM
ROBS6T8's Avatar
Robert
Fred, if I recall right, I think he's talking about where the arms actually bolt to the tower.
Old Feb 15th, 13, 08:09 AM
Anthony
Are the kyb shocks really that bad? I already have them and didnt get the bilsteins yet but was going to order them on payday. As for the slugs the e bay arms had a part that was the cause for them failing, they are the pieces that bolt directly onto the car I found a link to some slugs but do not know which ones exactly to get. there are many different sizes and material options. I just know I want them in steel but dont know the proper size. Here is a link to the slugs I spoke of, I dont know which are the right ones http://pitstopusa.com/search-1.html?q=slugs
Yes I did my research on the e bay arms thats how I discovered the flaw in the slugs in the first place. There are a few different threads on this site however none give a specific link to just one part that would be a sufficient replacement. I have tried search however some of the older link I discovered are no longer showing up and the members I have sent direct messages to in order to see what slugs they used have not responded. I think the slugs in the newer arms are actally safe but I am not certain. Do I have to cut the springs some? On that Pozziracing site there was a comment to cut the springs some, I am just checking to see what you guys think.
I am not sure, I know some people really dont trust them but the ones that failed were like from over 5 years ago I think, they mount in direct replacement where the stock a arms do.
Old Feb 15th, 13, 09:08 AM
zlek131 zlek131 is offline
Matt
Yeah loose the KYB for sure! KYB=Kick Your Butt or Kill Your Back. Had KYB's on my 72 and replaced them with Koni's and the difference is night and day. Regarding your upgrade, I did a very similar upgrade to my 68 and did it all by myself. It's totally doable if you have the patience and turned a wrench or two in the past.
Matt
68 RS
72 RS/SS
Go for a 68 ride
Old Feb 15th, 13, 09:41 AM
Anthony
How long did it take you to complete the install?
Old Feb 15th, 13, 09:58 AM
Matt
I did mine over winter working mostly on weekends and taking my time to make sure I did it right. I also did a bit more than what you are thinking about doing. Mine also included del-a-lam rear leaf springs, new rear end, drum to disc brake conversion on all corners, new brake lines/master cylinder, wheels and tires and a bunch of other little things that fall into the "while I am down here" category. I also had to address some issues (introduced by previous owner) that I found. Shocks will be easy and will take you a Saturday or less given you'll be doing these last and you'll have already removed the old front shocks as part of the other front end work. Front springs, upper/lower arms and sway bar is more like a multi weekend job for us average guys that don't do this every month. Just take your time and enjoy.
Matt
68 RS
72 RS/SS
Go for a 68 ride
Old Feb 15th, 13, 10:54 AM
Anthony
Thanks Matt! I appreciate that.
Old Feb 15th, 13, 04:43 PM
scblucam's Avatar
scblucam scblucam is offline
Scott
If you don't keep stopping for liquid refreshments it can be done in a day. Save the refreshments until the springs are out and back in. Be safe.
68 302 M20 - 85 IROC Z
